Mapping created using Template does not work
I have setup ELK stack and I am going by default index name, which is
logstash-YYYY.MM.DD . Since this is the only index format I have, I decided
to create a template file, so that whenever new index gets created i can
set up the mapping property. I am not able to push the data to
elasticsearch if my index mapping gets created from template. May I know
where am I wrong ?
Here is my mapping file content:
"X_Server" : {
"properties" : {
"@timestamp" : {
"type" : "date",
"format" : "dateOptionalTime"
"@version" : { "type" : "string" },
"class" : { "type" : "string" },
"file" : { "type" : "string"},
"message": {"type": "string"},
"host" : { "type" : "string", "index": "not_analyzed" }
My template file content is
"template": "logstash-*",
"settings" : {
"index.number_of_shards" : 3,
"index.number_of_replicas" : 1,
"index.query.default_field" : "@message",
"index.routing.allocation.total_shards_per_node" : 2,
"index.auto_expand_replicas": false
"mappings": {
"X_Server": {
"_all": { "enabled": false },
"_source": { "compress": false },
"properties" : {
"class" : { "type" : "string", },
"host" : { "type" : "string", "index" : "not_analyzed" },
"file" : { "type" : "string" },
"message" : { "type": "string"}
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/b1d382b5-0fa7-4a2c-96f0-150d856482cc%40googlegroups.com.
Hey,
can you include a full example including data you have been indexing? Or
include error messages, as you wrote you cannot index any data anymore?
Also, your JSON is not valid as the mapping for the class field contains a
comma too much.
--Alex
On Thu, May 1, 2014 at 1:53 AM, Deepak Jha dkjhanitt@gmail.com wrote:
where am I wrong ?
"X_Server" : {
"properties" : {
"@timestamp" : {
"type" : "date",
"settings" : {
"mappings": {
"X_Server": {
"properties" : {
https://groups.google.com/d/msgid/elasticsearch/b1d382b5-0fa7-4a2c-96f0-150d856482cc%40googlegroups.comhttps://groups.google.com/d/msgid/elasticsearch/b1d382b5-0fa7-4a2c-96f0-150d856482cc%40googlegroups.com?utm_medium=email&utm_source=footer
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/CAGCwEM8%2BeqGWt9H%2BbJKLg0B5KfmOSjyGhfDXvWFdQgaR4tWQ4w%40mail.gmail.com.
Hi Alex,
I am using logstash to index my data to elasticsearch. When I do not use
this template I am able to push data.
Here is the few lines from the log file that I have:
2014-05-05 14:51:20,248 (main) a_class INFO: message1
2014-05-05 14:51:20,249 (main) a_class INFO: message2
2014-05-05 14:51:20,510 (main) b_class INFO: message3
2014-05-05 14:51:20,597 (main) x_class INFO: message4
2014-05-05 14:51:20,701 (main) d_class INFO: message5
My grok parser is
SERVERLOG %{TIMESTAMP_ISO8601} (%{NOTSPACE:thread}) %{WORD:class}
%{LOGLEVEL:severity}: %{GREEDYDATA:message}
Attached my template.json.. Thanks a lot for your help.
I am processing these in logstash
On Monday, May 5, 2014 3:37:52 AM UTC-7, Alexander Reelsen wrote:
Hey,
comma too much.
--Alex
On Thu, May 1, 2014 at 1:53 AM, Deepak Jha <dkjh...@gmail.com<javascript:>
wrote:
where am I wrong ?
"X_Server" : {
"properties" : {
"@timestamp" : {
"type" : "date",
"settings" : {
"mappings": {
"X_Server": {
"properties" : {
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/2b5c8869-743e-4401-829e-6cac4ccbab75%40googlegroups.com.
Hey,
can you just take some sample data and index it into elasticsearch manually
and see if that works?
--Alex
where am I wrong ?
"X_Server" : {
"properties" : {
"@timestamp" : {
"type" : "date",
"settings" : {
"mappings": {
"X_Server": {
"properties" : {
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/CAGCwEM8YwuhQBz6Th%2B0VsmUrRwZXnVqHe8SwV_2gemyQ3oURJQ%40mail.gmail.com.
Hi Alexander,
Yes it works when I remove the template setting.
On Friday, May 9, 2014 12:26:49 PM UTC-7, Alexander Reelsen wrote:
Hey,
manually and see if that works?
--Alex
wrote:
where am I wrong ?
"X_Server" : {
"properties" : {
"@timestamp" : {
"type" : "date",
"settings" : {
"mappings": {
"X_Server": {
"properties" : {
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/76e896a0-8e74-417b-8027-63b3fe67f2bc%40googlegroups.com.
