Max_children,0 does not appear to work in has_child filter?
I want to be able to select parents that don't have any children matching a particular set of criteria. I thought that if I did:
          "has_child": {
            "max_children": 0,
            "type": "event",
            "filter": {
              "bool": {
                "must": [
                    "bool": {
                      "must": [
                          "term": {
                            "cs_e": "eventF"
                      "should": [],
                      "mustNot": []
                "should": [],
                "mustNot": []
then this would return me parents who had a maximum of 0 children - ie the parents that don't match. Curiously, however, I do get one parent back from the query, and that parent has one child that matches.
Is this expected? (Possibly I have messed up somewhere or misunderstood)?
Many thanks!
Hey there -> did you ever get an answer to this question? I am running into the same issue
