What is the total max size that an engine can have, is there a limit to it and if yes, is it configurable?
Hi Subhasis -
There are a number of different limits for App Search engines, many of them are configurable. Perhaps the best guide is the documentation at:
https://www.elastic.co/guide/en/app-search/current/limits.html
Let us know if this helps, or if there is anything specific in the limits that are affecting you. Thanks!
HI Mark, I went through these limits but no where its mentioned, what is the max limit an engine can handle
Hi Subhasis,
Assuming you mean scales like documents and/or query volume, there is no concrete limit.
Best,
Quin
