I'm following example in https://www.elastic.co/guide/en/watcher/current/watching-marvel-data.html#watching-memory-usage , I'm currently using elasticsearch, kibana and metricbeat version 5.4.1 setup on windows10. I created watcher memory usage and cpu usage i should get alert with email. When i executed the watch api, I'm getting this error as given below.
"error": {
"root_cause": [
"type": "general_script_exception",
"reason": "failed to compile script [ScriptException[compile error]; nested: IllegalArgumentException[unexpected token ['{'] was expecting one of [{, ';'}].];]"
"status": 500
And i find this forum same issue, but no team to reply it at link CPU usage and Memory usage
Can anyone help me out with the situation.
Thanks!
Dol
#Sorry for a little grammar
PUT _xpack/watcher/watch/mem_watch
"trigger": {
"schedule": {
"interval": "1m"
"input": {
"search": {
"request": {
"indices": [
"metricbeat-*"
"types" : [
"node_stats"
"body": {
"size" : 0,
"bool": {
"filter": {
"range": {
"timestamp": {
"gte": "now-2m",
"lte": "now"
"aggs": {
"minutes": {
"date_histogram": {
"field": "timestamp",
"interval": "minute"
"aggs": {
"nodes": {
"terms": {
"field": "source_node.name",
"size": 10,
"order": {
"memory": "desc"
"aggs": {
"memory": {
"avg": {
"field": "node_stats.jvm.mem.heap_used_percent"
"throttle_period": "30m",
"condition": {
"script": "if (ctx.payload.aggregations.minutes.buckets.size() == 0) return false; def latest = ctx.payload.aggregations.minutes.buckets[-1]; def node = latest.nodes.buckets[0]; return node && node.memory && node.memory.value >= 75;"
"actions": {
"send_email": {
"transform": {
"script": "def latest = ctx.payload.aggregations.minutes.buckets[-1]; return latest.nodes.buckets.findAll { return it.memory && it.memory.value >= 75 };"
"email": {
"to": "example.email@domain.com",
"subject": "Watcher Notification - HIGH MEMORY USAGE",
"body": "Nodes with HIGH MEMORY Usage (above 75%):\n\n{{#ctx.payload._value}}\"{{key}}\" - Memory Usage is at {{memory.value}}%\n{{/ctx.payload._value}}"
this is my code.
spinscale
(Alexander Reelsen)
July 3, 2017, 8:16am
3
The example you are checking out is for watching marvel data. Marvel was used in Elasticsearch 2.x, not in 5.x - and the example is also tailored for 2.x. because of this it used groovy as a scripting language, but you need to change those to use painless.
You can check out the alerting examples in our examples repo for some painless scripting examples..
thanks for advice me. @spinscale
i'll try again. if i have issue i will come back to ask you again.
PUT _xpack/watcher/watch/mem_warning
"trigger": {
"schedule": {
"interval": "10m"
"input": {
"search": {
"request": {
"indices": [
"metricbeat-*"
"types" : [
"metricsets"
"body": {
"size": 0,
"bool": {
"filter": [
"range": {
"@timestamp ": {
"gte": "now-7h",
"lte": "now"
"aggs": {
"minutes": {
"date_histogram": {
"field": "@timestamp ",
"interval": "10m"
"aggs": {
"hosts": {
"terms": {
"field": "beat.hostname",
"size": 10
"aggs": {
"memory_over_75": {
"filters": {
"filters": {
"high": {
"range": {
"system.memory.used.pct": {
"gte": 75
"low": {
"range": {
"lt": 75
"condition": {
"script": "if (ctx.payload.aggregations.minutes.buckets.size() != 0) return true; def latest = ctx.payload.aggregations.minutes.buckets[-1]; def node = latest.hosts.buckets[0]; return doc['hosts'] && doc['system.memory.total'].value && doc['system.memory.used.pct'].value >= 75;"
"actions": {
"send_email": {
"email": {
"to": "thanadol.thad@wealth.co.th",
"body": "Nodes with HIGH MEMORY Usage (above 75%):\n\n{{#ctx .payload._value}}"{{key}}" - Memory Usage is at {{memory.value}}%\n{{/ctx.payload._value}}"
Hi @spinscale ,
i want you to introduce the show output actions body. result host name and mem used values more than 75%
thanks.
spinscale
(Alexander Reelsen)
July 5, 2017, 7:17am
6
hey
just to be sure. Is this working as expected now for you? Or was there a question hidden in your last post, which we need to work on?
--Alex
thanks for reply @spinscale
i'm not sure this code is correct. because this result email actions is "
Nodes with HIGH MEMORY Usage (above 75%): "
And result execute_api
"result": {
"execution_time": "2017-07-05T08:18:14.619Z",
"execution_duration": 14044,
"input": {
"type": "search",
"status": "success",
"payload": {
"_shards": {
"total": 50,
"failed": 0,
"successful": 50
"hits": {
"hits": ,
"total": 329920,
"max_score": 0
"took": 6108,
"timed_out": false,
"aggregations": {
"minutes": {
"buckets": [
"key_as_string": "2017-07-05T01:50:00.000Z",
"doc_count": 502,
"hosts": {
"doc_count_error_upper_bound": 0,
"sum_other_doc_count": 0,
"buckets": [
"doc_count": 502,
"memory_over_75": {
"buckets": {
"high": {
"doc_count": 0
"low": {
"doc_count": 7
"key": "DESKTOP-QDUTNR1"
"key": 1499219400000
"search": {
"request": {
"indices": [
"metricbeat-*"
"types": [
"metricsets"
"body": {
"size": 0,
"bool": {
"filter": [
"range": {
"@timestamp ": {
"gte": "now-7h",
"lte": "now"
"aggs": {
"minutes": {
"date_histogram": {
"interval": "10m"
"aggs": {
"hosts": {
"terms": {
"size": 10
"aggs": {
"memory_over_75": {
"filters": {
"filters": {
"high": {
"range": {
"gte": 75
"low": {
"range": {
"lt": 75
"condition": {
"type": "script",
"met": true
"actions": [
"id": "send_email",
"type": "email",
"email": {
"account": "gmail_account",
"message": {
"id": "mem_warning_2ad2b2fb-4177-401e-b50c-6706a6f46926-2017-07-05T08:18:14.619Z",
"sent_date": "2017-07-05T08:18:22.203Z",
"to": [
"body": {
"text": """
"messages":
--Dol
