Metric beat is not pushing data to elastic search - I am using metric beat to monitor host and dockers
This is for Host
metricbeat.modules:
output.elasticsearch:
username: "metricbeat_anonymous_user"
#password: ""
hosts: ["${HOST_ELASTICSEARCH}"]
setup.kibana:
host: "${HOST_KIBANA}"
#============================== Dashboards =====================================
# These settings control loading the sample dashboards to the Kibana index. Loading
# the dashboards is disabled by default and can be enabled either by setting the
# options here, or by using the `-setup` CLI flag.
setup.dashboards.enabled: true
logging.level: warning
logging.to_files: true
logging.to_syslog: false
logging.files:
path: /var/log/metricbeat
keepfiles: 2
permissions: 0644
This is for containers -
metricbeat.modules: - module: system metricsets: ["cpu", "load", "filesystem", "fsstat", "memory", "network", "process", "core", "diskio", "socket"] period: 5s enabled: true processes: ['.*'] cpu.metrics: ["percentages"] core.metrics: ["percentages"] #------------------------------- Docker Module ------------------------------- - module: docker metricsets: ["container", "cpu", "diskio", "healthcheck", "info", "memory", "network"] hosts: ["unix:///var/run/docker.sock"] enabled: true period: 5s #-------------------------- Elasticsearch output ------------------------------ output.elasticsearch: username: "metricbeat_anonymous_user" #password: "" hosts: ["{HOST_ELASTICSEARCH}"] setup.kibana: host: "{HOST_KIBANA}" setup.dashboards.enabled: true logging.level: warning logging.to_files: true logging.to_syslog: false logging.files: -----
My docker-compose file -
version: "2.2" services: # Used as the Metricbeat output # Of course, we could create a cluster with more nodes elasticsearch: image: docker.elastic.co/elasticsearch/elasticsearch:6.5.4 container_name: metricbeat-elasticsearch memswap_limit: 0 mem_limit: 2g cap_add: - IPC_LOCK environment: - cluster.name=docker-cluster - bootstrap.memory_lock=true - "ES_JAVA_OPTS=-Xms1g -Xmx1g" ulimits: memlock: soft: -1 hard: -1 volumes: - ./config/usr/share/elasticsearch/config/elasticsearch.yml:/usr/share/elasticsearch/config/elasticsearch.yml ports: - "9222:9200" networks: - metricbeat
Continuation .... docker-compose
Used to analyse data sent to elasticsearch from Metricbeat. # Metricbeat directly creates Dashbords into Kibana kibana: image: docker.elastic.co/kibana/kibana:6.5.4 container_name: metricbeat-kibana volumes: - ./config/opt/kibana/config/kibana.yml:/opt/kibana/config/kibana.yml depends_on: - elasticsearch ports: - "5666:5601" networks: - metricbeat
continuation docker compose for metric beat -
metricbeat: build: ./docker/metricbeat container_name: metricbeat-metricbeat-services command: -e environment: - "WAIT_FOR_HOSTS=elasticsearch:9200 kibana:5601" - "HOST_ELASTICSEARCH=elasticsearch:9200" - "HOST_KIBANA=kibana:5601" depends_on: - elasticsearch networks: - metricbeat
for metricbeat -host portion
metricbeat-host: build: context: ./docker/metricbeat args: - METRICBEAT_FILE=metricbeat-host.yml container_name: metricbeat-metricbeat-host command: -system.hostfs=/hostfs volumes: - /proc:/hostfs/proc:ro - /sys/fs/cgroup:/hostfs/sys/fs/cgroup:ro - /:/hostfs:ro - /var/run/docker.sock:/var/run/docker.sock environment: - "WAIT_FOR_HOSTS=elasticsearch:9222 kibana:5666" - "HOST_ELASTICSEARCH=elasticsearch:9222" - "HOST_KIBANA=kibana:5666" extra_hosts: - "elasticsearch:172.17.0.1" # The IP of docker0 interface to access host from container - "kibana:172.17.0.1" # The IP of docker0 interface to access host from container network_mode: host # Mandatory to monitor HOST filesystem, memory, processes,... networks: metricbeat: external: name: metricbeat
This Waiting for Cluster... message continuously coming. Using ELK -6.5.4 and Metricbeat 6.5.4
Any suggestions.
