Metricbeat and Heartbeat 8.x custom index Name should pickup from template ,but creates always bedefault index name
8.7.1 Works exactly the same using the process above (manually installing ILM and Template) I just changed the version numbers from 8.8.0 to 8.7.1
I am not sure what your issue is. I just tested it, works exactly the same you have a typo or mismatch somewhere
My 8.7.1
setup.ilm.enabled: false
setup.template.enabled: false
output.elasticsearch:
  hosts: ["http://localhost:9200"]
  index: "cis-metric-%{[agent.version]}"
After running metricbeat 8.7.1
GET _data_stream/cis-metric-8.7.1
  "data_streams": [
      "name": "cis-metric-8.7.1",
      "timestamp_field": {
        "name": "@timestamp"
      "indices": [
          "index_name": ".ds-cis-metric-8.7.1-2023.07.11-000001",
          "index_uuid": "6c6CMe6IStqPsnQ5EMN4qw"
      "generation": 1,
      "status": "YELLOW",
      "template": "cis-metric-8.7.1",
      "ilm_policy": "cis-metric-policy",
      "hidden": false,
      "system": false,
      "allow_custom_routing": false,
      "replicated": false
Sure we put the version number in to allow for changes between versions if needed.
You will just need to make sure you make the proper changes and take out the version number everywhere...
But the fact it is not working means you have something else going on... you should find it....
Just for reference here is the 8.7.1 code I gave you the metricbeat.yml section above
DELETE _data_stream/cis-metric-8.7.1
GET _ilm/policy/cis-metric-policy
DELETE _ilm/policy/cis-metric-policy
PUT _ilm/policy/cis-metric-policy
  "policy": {
    "phases": {
      "hot": {
        "min_age": "0ms",
        "actions": {
          "rollover": {
            "max_age": "30d",
            "max_primary_shard_size": "50gb"
DELETE _index_template/cis-metric-8.7.1
PUT _index_template/cis-metric-8.7.1
  "index_patterns": [
    "cis-metric-8.7.1"
  "template": {
    "settings": {
      "index": {
        "lifecycle": {
          "name": "cis-metric-policy"
        "mapping": {
          "total_fields": {
            "limit": "10000"
        "number_of_shards": "1"
    "mappings": {
      "properties": {
        "system.cpu.iowait.norm.pct": {
          "scaling_factor": 1000,
          "type": "scaled_float"
        "system.process.memory.rss.pct": {
        "system.diskio.write.bytes": {
          "type": "long"
        "system.load.cores": {
          "type": "long"
        "system.process.cpu.total.value": {
          "type": "long"
        "service.type": {
          "type": "keyword"
        "system.diskio.iostat.service_time": {
          "type": "float"
        "system.memory.actual.free": {
          "type": "long"
        "system.cpu.idle.norm.pct": {
        "agent.name": {
          "type": "keyword"
        "system.memory.total": {
          "type": "long"
        "system.diskio.write.time": {
          "type": "long"
        "process.ppid": {
          "type": "long"
        "system.diskio.iostat.write.await": {
          "type": "float"
        "system.fsstat.total_size.free": {
          "type": "long"
        "system.memory.free": {
          "type": "long"
        "system.memory.swap.free": {
          "type": "long"
        "system.memory.actual.used.pct": {
          "scaling_factor": 100,
        "system.diskio.iostat.queue.avg_size": {
          "type": "float"
        "agent.id": {
          "type": "keyword"
        "system.memory.actual.used.bytes": {
          "type": "long"
        "system.diskio.iostat.busy": {
          "type": "float"
        "system.diskio.name": {
          "type": "keyword"
        "system.cpu.user.pct": {
        "system.memory.used.bytes": {
          "type": "long"
        "system.network.name": {
          "type": "keyword"
        "system.diskio.iostat.request.avg_size": {
          "type": "float"
        "system.diskspace.usage": {
          "type": "long"
        "system.cpu.system.pct": {
        "system.diskio.iostat.read.request.merges_per_sec": {
          "type": "float"
        "system.cpu.irq.pct": {
        "process.type": {
          "type": "keyword"
        "process.details": {
          "type": "keyword"
        "system.cpu.user.norm.pct": {
        "user.name": {
          "type": "text",
          "fields": {
            "keyword": {
              "ignore_above": 256,
              "type": "keyword"
        "system.network.in.bytes": {
          "type": "long"
        "system.network.in.dropped": {
          "type": "long"
        "system.diskio.io.ops": {
          "type": "long"
        "mountpoint.details": {
          "type": "keyword"
        "system.diskio.iostat.write.per_sec.bytes": {
          "type": "float"
        "system.fsstat.count": {
          "type": "long"
        "system.load.1": {
        "system.process.cpu.total.ticks": {
          "type": "long"
        "system.cpu.softirq.norm.pct": {
        "system.cpu.nice.pct": {
        "system.load.5": {
        "metricset.period": {
          "type": "long"
        "system.diskio.iostat.read.per_sec.bytes": {
          "type": "float"
        "system.process.memory.share": {
          "type": "long"
        "process.pgid": {
          "type": "long"
        "system.process.memory.rss.bytes": {
          "type": "long"
        "@timestamp": {
          "type": "date"
        "system.network.in.errors": {
          "type": "long"
        "system.process.cpu.total.norm.pct": {
        "system.cpu.nice.norm.pct": {
        "system.memory.used.pct": {
        "system.diskio.iostat.read.await": {
          "type": "float"
        "system.cpu.irq.norm.pct": {
        "process.pid": {
          "type": "long"
        "system.load.norm.15": {
        "system.diskio.read.count": {
          "type": "long"
        "system.filesystem.used.pct": {
          "type": "float"
        "system.cpu.iowait.pct": {
        "system.process.memory.size": {
          "type": "long"
        "system.network.out.dropped": {
          "type": "long"
        "cpu.status": {
          "type": "keyword"
        "host.name": {
          "type": "text",
          "fields": {
            "keyword": {
              "type": "keyword"
        "system.diskio.iostat.await": {
          "type": "float"
        "system.network.out.packets": {
          "type": "long"
        "system.cpu.steal.norm.pct": {
        "system.cpu.steal.pct": {
        "system.diskio.write.count": {
          "type": "long"
        "process.name": {
          "type": "text",
          "fields": {
            "keyword": {
              "type": "keyword"
        "system.diskio.read.time": {
          "type": "long"
        "system.diskio.serial_number": {
          "type": "keyword"
        "system.fsstat.total_files": {
          "type": "long"
        "system.network.in.packets": {
          "type": "long"
        "system.cpu.total.pct": {
        "system.network.out.errors": {
          "type": "long"
        "system.diskio.iostat.write.request.merges_per_sec": {
          "type": "float"
        "system.memory.swap.total": {
          "type": "long"
        "system.diskio.io.time": {
          "type": "long"
        "system.cpu.total.norm.pct": {
        "system.load.15": {
        "system.cpu.cores": {
          "type": "long"
        "system.fsstat.status": {
          "type": "keyword"
        "system.cpu.softirq.pct": {
        "system.load.norm.5": {
        "system.diskio.iostat.write.request.per_sec": {
          "type": "float"
        "system.diskio.read.bytes": {
          "type": "long"
        "system.fsstat.total_size.used": {
          "type": "long"
        "system.load.norm.1": {
        "system.process.cpu.start_time": {
          "type": "date"
        "system.memory.swap.used.pct": {
        "system.cpu.idle.pct": {
        "system.diskio.iostat.read.request.per_sec": {
          "type": "float"
        "system.network.out.bytes": {
          "type": "long"
        "system.memory.swap.used.bytes": {
          "type": "long"
        "process.args": {
          "type": "keyword"
        "system.cpu.system.norm.pct": {
        "system.process.cpu.total.pct": {
        "metricset.name": {
          "type": "keyword"
        "system.fsstat.total_size.total": {
          "type": "long"
        "system.process.state": {
          "type": "keyword"
  "composed_of": [],
  "data_stream": {
    "hidden": false,
I've noticed in addition to datastream below is also getting created:
Yes that is called the Backing Index... you should read about Data Streams...
