Metricbeat only run system module instead of running both system and apache module
Hi all,
I configured metricbeat on my server for collecting both system & apache data with default module but only system data from host showed on kibana. The apache dashboard is empty data and don't know the reason.
here is my apache.yml module:
# Module: apache
# Docs: https://www.elastic.co/guide/en/beats/metricbeat/7.9/metricbeat-module-apache.html
- module: apache
  metricsets:
    - status
  period: 10s
  hosts: ["http://127.0.0.1"]
  #username: "user"
  #password: "secret"
What else I need to config or check to resolve the problem?
Hi @Minh_Ti_n_Tr_n :slightly_smiling_face:
Which steps did you follow on the cli to activate the module? did you execute metricbeat modules enable apache for example? Can you also paste your metricbeat.yml?
Yes I ran that command
Here is metricbeat.yml
###################### Metricbeat Configuration Example #######################
# This file is an example configuration file highlighting only the most common
# options. The metricbeat.reference.yml file from the same directory contains all the
# supported options with more comments. You can use it as a reference.
# You can find the full configuration reference here:
# https://www.elastic.co/guide/en/beats/metricbeat/index.html
# =========================== Modules configuration ============================
metricbeat.config.modules:
  reload.enabled: false
  #reload.period: 10s
# ======================= Elasticsearch template setting =======================
setup.template.settings:
  index.number_of_shards: 1
  index.codec: best_compression
  #_source.enabled: false
# ================================== General ===================================
# The name of the shipper that publishes the network data. It can be used to group
# all the transactions sent by a single shipper in the web interface.
#name:
# The tags of the shipper are included in their own field with each
# transaction published.
# Optional fields that you can specify to add additional information to the
# output.
#fields:
#  env: staging
# ================================= Dashboards =================================
# These settings control loading the sample dashboards to the Kibana index. Loading
# the dashboards is disabled by default and can be enabled either by setting the
# options here or by using the `setup` command.
#setup.dashboards.enabled: false
# The URL from where to download the dashboards archive. By default this URL
# has a value which is computed based on the Beat name and version. For released
# versions, this URL points to the dashboard archive on the artifacts.elastic.co
# website.
#setup.dashboards.url:
# =================================== Kibana ===================================
# Starting with Beats version 6.0.0, the dashboards are loaded via the Kibana API.
# This requires a Kibana endpoint configuration.
setup.kibana:
  # Kibana Host
  # Scheme and port can be left out and will be set to the default (http and 5601)
  # In case you specify and additional path, the scheme is required: http://localhost:5601/path
  # IPv6 addresses should always be defined as: https://[2001:db8::1]:5601
  host: "https://192.168.87.47:443"
  ssl.verification_mode: "none"
  # Kibana Space ID
  # ID of the Kibana Space into which the dashboards should be loaded. By default,
  # the Default Space will be used.
  #space.id:
# =============================== Elastic Cloud ================================
# These settings simplify using Metricbeat with the Elastic Cloud (https://cloud.elastic.co/).
# The cloud.id setting overwrites the `output.elasticsearch.hosts` and
# `setup.kibana.host` options.
# You can find the `cloud.id` in the Elastic Cloud web UI.
#cloud.id:
# The cloud.auth setting overwrites the `output.elasticsearch.username` and
# `output.elasticsearch.password` settings. The format is `<user>:<pass>`.
#cloud.auth:
# ================================== Outputs ===================================
# ---------------------------- Elasticsearch Output ----------------------------
output.elasticsearch:
  hosts: ["https://192.168.87.47:9200"]
  # Protocol - either `http` (default) or `https`.
  #protocol: "https"
  # Authentication credentials - either API key or username/password.
  #api_key: "id:api_key"
  username: "elastic"
  password: "<password>"
# ------------------------------ Logstash Output -------------------------------
#output.logstash:
  # The Logstash hosts
  #hosts: ["localhost:5044"]
  # Optional SSL. By default is off.
  # Client Certificate Key
# ================================= Processors =================================
# Configure processors to enhance or manipulate events generated by the beat.
processors:
  - add_host_metadata: ~
  - add_cloud_metadata: ~
  - add_docker_metadata: ~
  - add_kubernetes_metadata: ~
# ================================== Logging ===================================
# Sets log level. The default log level is info.
# Available log levels are: error, warning, info, debug
#logging.level: debug
# At debug level, you can selectively enable logging only for some components.
# To enable all selectors use ["*"]. Examples of other selectors are "beat",
# "publish", "service".
#logging.selectors: ["*"]
# ============================= X-Pack Monitoring ==============================
# Metricbeat can export internal metrics to a central Elasticsearch monitoring
# cluster.  This requires xpack monitoring to be enabled in Elasticsearch.  The
# reporting is disabled by default.
# Set to true to enable the monitoring reporter.
#monitoring.enabled: false
# Sets the UUID of the Elasticsearch cluster under which monitoring data for this
# Metricbeat instance will appear in the Stack Monitoring UI. If output.elasticsearch
# is enabled, the UUID is derived from the Elasticsearch cluster referenced by output.elasticsearch.
#monitoring.cluster_uuid:
# Uncomment to send the metrics to Elasticsearch. Most settings from the
# Elasticsearch output are accepted here as well.
# Note that the settings should point to your Elasticsearch *monitoring* cluster.
# Any setting that is not set is automatically inherited from the Elasticsearch
# output configuration, so if you have the Elasticsearch output configured such
# that it is pointing to your Elasticsearch monitoring cluster, you can simply
# uncomment the following line.
#monitoring.elasticsearch:
# ============================== Instrumentation ===============================
# Instrumentation support for the metricbeat.
#instrumentation:
    # Set to true to enable instrumentation of metricbeat.
    #enabled: false
    # Environment in which metricbeat is running on (eg: staging, production, etc.)
    #environment: ""
    # APM Server hosts to report instrumentation results to.
    #hosts:
    #  - http://localhost:8200
    # API Key for the APM Server(s).
    # If api_key is set then secret_token will be ignored.
    #api_key:
    # Secret token for the APM Server(s).
    #secret_token:
# ================================= Migration ==================================
# This allows to enable 6.7 migration aliases
#migration.6_to_7.enabled: true
What is the output from metricbeat modules list?
Here
Enabled:
apache
system
Disabled:
activemq
aerospike
appsearch
aws
azure
beat
beat-xpack
ceph
ceph-mgr
cloudfoundry
cockroachdb
consul
coredns
couchbase
couchdb
docker
dropwizard
elasticsearch
elasticsearch-xpack
envoyproxy
etcd
golang
googlecloud
graphite
haproxy
http
ibmmq
iis
istio
jolokia
kafka
kibana
kibana-xpack
kubernetes
kvm
linux
logstash
logstash-xpack
memcached
mongodb
mssql
munin
mysql
nats
nginx
openmetrics
oracle
php_fpm
postgresql
prometheus
rabbitmq
redis
redisenterprise
sql
stan
statsd
tomcat
traefik
uwsgi
vsphere
windows
zookeeper
Thanks!
Can you post your Metricbeat logs from startup onwards please?
Sorry but I dont understand what logs from startup onwards is
I will attach full metricbeat log
 systemctl status metricbeat -l
● metricbeat.service - Metricbeat is a lightweight shipper for metrics.
   Loaded: loaded (/lib/systemd/system/metricbeat.service; enabled; vendor preset: enabled)
   Active: active (running) since Thu 2020-12-10 06:31:15 UTC; 13s ago
     Docs: https://www.elastic.co/products/beats/metricbeat
 Main PID: 118846 (metricbeat)
    Tasks: 10 (limit: 9470)
   CGroup: /system.slice/metricbeat.service
           └─118846 /usr/share/metricbeat/bin/metricbeat --environment systemd -c /etc/metricbeat/metricbeat.yml --path.home /usr/share/metricbeat --path.con
Dec 10 06:31:16 server metricbeat[118846]: 2020-12-10T06:31:16.419Z        INFO        [index-management]        idxmgmt/std.go:274        ILM policy success
Dec 10 06:31:16 eramba metricbeat[118846]: 2020-12-10T06:31:16.419Z        INFO        [index-management]        idxmgmt/std.go:407        Set setup.template
Dec 10 06:31:16 eramba metricbeat[118846]: 2020-12-10T06:31:16.419Z        INFO        [index-management]        idxmgmt/std.go:412        Set setup.template
Dec 10 06:31:16 eramba metricbeat[118846]: 2020-12-10T06:31:16.419Z        INFO        [index-management]        idxmgmt/std.go:446        Set settings.index
Dec 10 06:31:16 eramba metricbeat[118846]: 2020-12-10T06:31:16.419Z        INFO        [index-management]        idxmgmt/std.go:450        Set settings.index
Dec 10 06:31:16 eramba metricbeat[118846]: 2020-12-10T06:31:16.421Z        INFO        template/load.go:89        Template metricbeat-7.9.3 already exists an
Dec 10 06:31:16 eramba metricbeat[118846]: 2020-12-10T06:31:16.421Z        INFO        [index-management]        idxmgmt/std.go:298        Loaded index templ
Dec 10 06:31:16 eramba metricbeat[118846]: 2020-12-10T06:31:16.423Z        INFO        [index-management]        idxmgmt/std.go:309        Write alias succes
Dec 10 06:31:16 eramba metricbeat[118846]: 2020-12-10T06:31:16.425Z        INFO        [publisher_pipeline_output]        pipeline/output.go:151        Conne
Dec 10 06:31:25 eramba metricbeat[118846]: 2020-12-10T06:31:25.433Z        INFO        module/wrapper.go:259        Error fetching data for metricset apache.
lines 1-19/19 (END)
root@server:/var/log/metricbeat# cat metricbeat
2020-12-10T06:17:25.398Z        INFO    instance/beat.go:640    Home path: [/usr/share/metricbeat] Config path: [/etc/metricbeat] Data path: [/var/lib/metricbeat] Logs path: [/var/log/metricbeat]
2020-12-10T06:17:25.398Z        INFO    instance/beat.go:648    Beat ID: a5fe1b39-25bb-4dd8-a46f-95fcba08e5fa
That's relevant. Is there more in /var/log/metricbeat that might reference apache?
What is the result of
curl http://127.0.0.1/status
It should be a lots of metrics there, if not, please check the apache configuration of server-status
no more log relate to apache :frowning:
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>302 Found</title>
</head><body>
<h1>Found</h1>
<p>The document has moved <a href="https://stagingdomain.com/status">here</a>.</p>
<hr>
<address>Apache/2.4.29 (Ubuntu) Server at 127.0.0.1 Port 80</address>
</body></html>
this is curl result
Some more information
    # metricbeat -e
    2020-12-10T09:08:53.492Z        INFO    instance/beat.go:640    Home path: [/usr/share/metricbeat] Config path: [/etc/metricbeat] Data path: [/var/lib/metricbeat] Logs path: [/var/log/metricbeat]
    2020-12-10T09:08:53.492Z        INFO    instance/beat.go:648    Beat ID: a5fe1b39-25bb-4dd8-a46f-95fcba08e5fa
    2020-12-10T09:08:53.494Z        INFO    instance/beat.go:387    metricbeat stopped.
    2020-12-10T09:08:53.495Z        ERROR   instance/beat.go:951    Exiting: data path already locked by another beat. Please make sure that multiple beats are not sharing the same data path (path.data).
You need to set the apache server-status to get the complete metric of Apache.
Still have problem with the locked data path
2020-12-11T02:11:56.202Z        ERROR   instance/beat.go:951    Exiting: data path already locked by another beat. Please make sure that multiple beats are not sharing the same data path (path.data).
Still not have any solution! :frowning:
So are you positive that there aren't any other beats running?
What's the output of lslocks | grep /var/lib/metricbeat/ ?
Is the output PID matches your current metricbeat PID?
Below is the result. They are match
root@server:/home/tienmtran# ps ax | grep metric
 70894 ?        Ssl   58:00 /usr/share/metricbeat/bin/metricbeat --environment systemd -c /etc/metricbeat/metricbeat.yml --path.home /usr/share/metricbeat --path.config /etc/metricbeat --path.data /var/lib/metricbeat --path.logs /var/log/metricbeat
111098 pts/0    S+     0:00 grep --color=auto metric
root@server:/home/tienmtran# lslocks | grep /var/lib/metricbeat/
metricbeat      70894 FLOCK   0B WRITE 0     0   0 /var/lib/metricbeat/metricbeat.lock
