Metricbeat timeout reading index_recovery, index_summary, etc
I am experiencing a problem where one of the elasticsearch clusters that I am monitoring within a Kubernetes cluster is having troubles being monitored with metricbeats.
The metricbeat agent is having problem with the following metricsets: index_recovery, index_summary, shard, ml_job and cluster_stats. While running the command:
./metricbeat test modules` I am getting the following error:
I am getting these errors:
index_recovery...
error... ERROR timeout waiting for an event
 index_summary...
shard...
ml_job...
 cluster_stats...
For the other metricset the data retreival is working, by example for index or node_stats
This is perfectly working in several other elasticsearch clusters.
What could be the problem? is there a way to increase the timeout?
Thanks,
Zareh
