I'm trying to use logstash to tail a log file, parse it, and both measure the stats on how many times a particular type of line shows up per minute and send that stat to graphite, and also send all parsed lines to elasticsearch.
I'm running into an issue where if I include the elasticsearch output, the metrics being sent to graphite are no longer being sent at the right intervals.
Here is an example config I have that has names altered:
  file {
    path => "/data/log/example.log"
    codec => plain
    sincedb_path => "/data/logstash/.sincedb"
    sincedb_write_interval => 5
  grok {
    match => { "message" => "^%{TIMESTAMP_ISO8601:ts} %{WORD:type}" }
    overwrite => [ "message" ]
  if [type] == "some_type" {
    grok {
      match => { "message" => "^some_message" }
      add_tag => [ "interesting_logline" ]
  if "interesting_logline" in [tags] {
    metrics {
      meter => [ "logstash.interesting_logline" ]
      clear_interval => 60
      flush_interval => 60
      add_tag => "metric"
      percentiles => []
      rates => []
  if "_grokparsefailure" in [tags] {
    file { path => "/data/log/logstash/parsefailure.log" }
  if "metric" in [tags] {
    graphite {
      host => "graphite-host"
      port => 2003
      include_metrics => [ "logstash.*" ]
      fields_are_metrics => true
      resend_on_failure => true
  else {
      hosts => ["elasticsearch:9200"]
      index => "logstash-%{+YYYY.MM.dd}"
      flush_size => 1000
      idle_flush_time => 10
      workers => 1
      codec => "json"
If I omit the elasticsearch output stanza, then I get metrics in graphite every 60 seconds like I expect. When I include it however, I only get metrics every few minutes sporadically. I've tried with logstash v2.3.2 and also v5.1.1, and both behave the same way. Is there something else I should be doing to get the metrics output to send consistently to graphite on a fixed interval?
