Minor problem with documentation for es debian installation
The documentation for installing the debian package suggests running:
echo "deb https://artifacts.elastic.co/packages/7.x/apt stable main" | sudo tee -a /etc/apt/sources.list.d/elastic-7.x.list
We added this to our chef scripts and this of course runs a lot and ends up appending the same line over and over again. This slows down apt-get operations to the point where it is unusable. When I checked the file it had 500 lines already.
I would suggest changing this to
echo "deb https://artifacts.elastic.co/packages/7.x/apt stable main" | sudo tee /etc/apt/sources.list.d/elastic-7.x.list
without the -a. or to
echo "deb https://artifacts.elastic.co/packages/7.x/apt stable main" > /etc/apt/sources.list.d/elastic-7.x.list
Hey Jilles,
do you mind open a PR or a doc issue for this one?
--Alex
Sure, I wasn't sure whether this needed further discussion or whether there is a usecase for this file to have multiple entries. Do you have separate tags for documentation issues?
indeed, there's a dedicated >docs tag
