Modify index.routing.allocation.total_shards_per_node by ILM when going to WARM
I have set "index.routing.allocation.total_shards_per_node" :1 in index template
for index with 6 primary shards. Because it is index intensive ETL and having shards on different nodes gives best performance results.
However I have only 4 warm nodes.
When index age moves shards to warm nodes it moves only 4 shards and 2 remains on hot nodes.
Is it possible to set "index.routing.allocation.total_shards_per_node" : null in ILM policy ?
It there a different approach how to achieve this (other than adding 2 warm nodes )?
thank you
It isn't today but it will be in 7.16:
great thank you.
I suppose I will use today as a workaround the"index.routing.allocation.total_shards_per_node" : 2
it will not perform as good as 1shard per node but it will shift all shards to warm nodes and resolve my problem.
Sounds reasonable. Elasticsearch should be trying to spread the shards of the index out across the nodes anyway, but doesn't guarantee to do so without this setting.
If there's a period of time between rolling over and moving the data to the warm nodes (e.g. you retain N days of completed indices on the hot nodes) then you can write yourself a script to remove index.routing.allocation.total_shards_per_node once the index has rolled over. That's something that I've seen other folks do to work around this.
