Would like to know the acceptable System Load metrics for elasticsearch data node which is between 0.5 to 3.
It depends on number of CPUs,
3 LA is OK for a box with 4+ cores, but may indicate an issue on single-CPU system.
Thanks. I believe similar interpretation is applicable for logstash node as well.
