Multi_match query for boolean fields is not work
Version ES 6.2.3.
Index
"_index": "test",
"_type": "doc",
"_id": "test",
"_score": 1,
"_source": {
"type": "my",
"updated_at": "2018-08-07T08:10:13.238Z",
"my": {
"title": "New My",
"System wide": true,
"Role wide": false,
"Roles": []
I need to find all documents with "*.System wide" field "true"
My query:
GET test/_search
"query": {"bool": {"must": [
"multi_match": {
"query": true,
"fields": ["*.System wide"]
What are the reasons for this behavior?
The mapping of this field is
"System wide": {
"type": "boolean"
It looks like a bug to me.
I reproduced it with:
DELETE index
PUT index/_doc/1
  "my": {
    "boolean": true,
    "text": "foo bar"
GET index/_search
    "multi_match": {
      "query": true,
      "fields": [ "my.*boolean"]
GET index/_search
    "multi_match": {
      "query": "foo",
      "fields": [ "my.*text"]
The former query does not work but the later does.
Would you like to open an issue with the script I shared as a way to reproduce the problem?
Yes. Where can I open issue?
Closing the loop here. As noted by @jimczi this issue has been reported here:
