I am running a single Node Elastic Cluster on a Server . Filebeat is used as collector for netflow data . Further FIlebeat is giving output to Elastic . Some Important Point
Server has 32 core CPU and 500 GB RAM . I see Elastic CPU load at around constant 60 % . Average system load for last 5 min is around 40
My Current Indexing speed in elastic is around 45000 /second . However I have input of around 80000 /second in peak time . Therefore in peak time I huge packet drops
From reading elastic documentation I see main bottle neck is elastic CPU usage . So I tried to debug this through hot threads API . Could anyone help me in understanding what further optimisation should I do
Hot Threads output is as follows
::: {single_noe}{lfOR4iS9TTCUZ5jWrkHBog}{jR0dgpikTDOBxkEa0ZGMDw}{127.0.0.1}{127.0.0.1:9300}{cdfhilmrstw}{ml.machine_memory=540121751552, xpack.installed=true, transform.node=true, ml.max_open_jobs=512, ml.max_jvm_size=274877906944}
Hot threads at 2022-11-18T05:11:24.749Z, interval=500ms, busiestThreads=3, ignoreIdleThreads=true:
100.0% [cpu=99.8%, other=0.2%] (500ms out of 500ms) cpu usage by thread 'elasticsearch[single_noe][[filebeat-7.13.3-2022.11.17-002536][0]: Lucene Merge Thread #628]'
2/10 snapshots sharing following 12 elements
app//org.apache.lucene.index.OrdinalMap.build(OrdinalMap.java:168)
app//org.apache.lucene.codecs.DocValuesConsumer.mergeSortedSetField(DocValuesConsumer.java:801)
app//org.apache.lucene.codecs.DocValuesConsumer.merge(DocValuesConsumer.java:145)
app//org.apache.lucene.codecs.perfield.PerFieldDocValuesFormat$FieldsWriter.merge(PerFieldDocValuesFormat.java:155)
app//org.apache.lucene.index.SegmentMerger.mergeDocValues(SegmentMerger.java:195)
app//org.apache.lucene.index.SegmentMerger.merge(SegmentMerger.java:150)
app//org.apache.lucene.index.IndexWriter.mergeMiddle(IndexWriter.java:4757)
app//org.apache.lucene.index.IndexWriter.merge(IndexWriter.java:4361)
app//org.apache.lucene.index.IndexWriter$IndexWriterMergeSource.merge(IndexWriter.java:5920)
app//org.apache.lucene.index.ConcurrentMergeScheduler.doMerge(ConcurrentMergeScheduler.java:626)
app//org.elasticsearch.index.engine.ElasticsearchConcurrentMergeScheduler.doMerge(ElasticsearchConcurrentMergeScheduler.java:94)
app//org.apache.lucene.index.ConcurrentMergeScheduler$MergeThread.run(ConcurrentMergeScheduler.java:684)
app//org.apache.lucene.codecs.lucene80.Lucene80DocValuesConsumer.addSortedSetField(Lucene80DocValuesConsumer.java:884)
app//org.apache.lucene.codecs.DocValuesConsumer.mergeSortedSetField(DocValuesConsumer.java:804)
app//org.apache.lucene.codecs.lucene80.Lucene80DocValuesConsumer.addSortedSetField(Lucene80DocValuesConsumer.java:924)
2/10 snapshots sharing following 16 elements
app//org.apache.lucene.codecs.DocValuesConsumer$SortedSetDocValuesSub.nextDoc(DocValuesConsumer.java:742)
app//org.apache.lucene.index.DocIDMerger$Sub.nextMappedDoc(DocIDMerger.java:56)
app//org.apache.lucene.index.DocIDMerger$SequentialDocIDMerger.next(DocIDMerger.java:116)
app//org.apache.lucene.codecs.DocValuesConsumer$5$1.nextDoc(DocValuesConsumer.java:848)
app//org.apache.lucene.codecs.lucene80.Lucene80DocValuesConsumer.addSortedSetField(Lucene80DocValuesConsumer.java:923)
app//org.apache.lucene.codecs.lucene80.Lucene80DocValuesConsumer.addSortedSetField(Lucene80DocValuesConsumer.java:940)
100.0% [cpu=99.7%, other=0.3%] (500ms out of 500ms) cpu usage by thread 'elasticsearch[single_noe][[filebeat-7.13.3-2022.11.17-002536][0]: Lucene Merge Thread #631]'
2/10 snapshots sharing following 5 elements
100.0% [cpu=99.7%, other=0.3%] (500ms out of 500ms) cpu usage by thread 'elasticsearch[single_noe][[filebeat-7.13.3-2022.11.17-002536][0]: Lucene Merge Thread #622]'
4/10 snapshots sharing following 12 elements
app//org.apache.lucene.util.PriorityQueue.downHeap(PriorityQueue.java:267)
app//org.apache.lucene.util.PriorityQueue.updateTop(PriorityQueue.java:202)
app//org.apache.lucene.util.bkd.BKDWriter.merge(BKDWriter.java:507)
app//org.apache.lucene.codecs.lucene86.Lucene86PointsWriter.merge(Lucene86PointsWriter.java:237)
app//org.apache.lucene.index.SegmentMerger.mergePoints(SegmentMerger.java:201)
app//org.apache.lucene.index.SegmentMerger.merge(SegmentMerger.java:161)
6/10 snapshots sharing following 9 elements
Following is the Cluster Info
"cluster_name" : "elasticsearch",
"status" : "yellow",
"timed_out" : false,
"number_of_nodes" : 1,
"number_of_data_nodes" : 1,
"active_primary_shards" : 122,
"active_shards" : 122,
"relocating_shards" : 0,
"initializing_shards" : 0,
"unassigned_shards" : 1,
"delayed_unassigned_shards" : 0,
"number_of_pending_tasks" : 0,
"number_of_in_flight_fetch" : 0,
"task_max_waiting_in_queue_millis" : 0,
"active_shards_percent_as_number" : 99.1869918699187
Please help me out if possible. Also, If there is something else needed, Please let me know.
