I'm facing a performance issue with some aggregations I perform, and I need
your help if possible:
I have to documents, the request and the event. The request is the
parent of the event. Below is a (sample) mapping
"event" : {
"dynamic" : "strict",
"_parent" : {
"type" : "request"
"properties" : {
"event_time" : {
"format" : "dateOptionalTime",
"type" : "date"
"count" : {
"type" : "integer"
"event" : {
"index" : "not_analyzed",
"type" : "string"
"request" : {
"_id" : {
"path" : "uniqueId"
"properties" : {
"uniqueId" : {
"type" : "string"
"user" : {
"type" : "string"
"code" : {
"type" : "integer"
"country" : {
"type" : "string"
"city" : {
"type" : "string"
My cluster is becoming really big (almost 2 TB of data with billions of
documents) and i maintain one index per day, whereas I occasionally delete
old indices. My daily index is about 20GB big. The version of elasticsearch
that I use is 1.1.1.
My problems start when I want to get some aggregations of events with some
criteria which is applied in the parent request document. For example count
be the events of type click for country = US and code=12. What I was
initially doing was to generate a scriptFilter for the request document (in
Groovy) and I was adding multiple aggregations in one search request. This
ended up being very slow so I removed the scripting logic and I supported
my logic with java code.
What seems to be initially solved in my local machine, when I got back to
the cluster, nothing has changed. Again my app performs really really poor.
I get more than 10 seconds to perform a search with ~10 sub-aggregations.
What seems strange is that I notice that the cluster is pretty ok with
regards load average, CPU etc.
Any hints on where to look for solving this out? to be able to identify the
bottleneck
Ask for any additional information to provide, I didn't want to make this
post too long to read
Thank you
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/8134f5b0-f947-406f-ab57-c44c6c82ce66%40googlegroups.com.
