Need help to properly map French cities for multi fields search and autocomplete
I'm currently working on French geolocation data.
Here is my model:
public class Ville
        public Guid Id { get; set; }
        public string Name { get; set; }
        public string ZipCode { get; set; }
        public string[] MultilpleZipCopde { get; set; }
        public GeoLocation Centroide { get; set; }
        public GeoLocation Min { get; set; }
        public GeoLocation Max { get; set; }
I need to be able to perform quick search such as:
  • search by name
  • search by zip code
  • perform autocomplete
I've facing some issues with:
  • the French language when there is an accent in the city name
  • the search on the zip code, the result of my search is empty when I set a zip code
I'm using ElasticSearch v7.2, .netCore, C#, Nest v7.0.1
Can someone give me a proper way to design my index's mapping & settings, please ?
I appreciate your help.
Thanks in advance,
Patrice
You can use the french analyzer or add an asciifolding token filter if you are using custom analyzer.
I wrote some examples at the end of this gist:
HTH
Hi David,
Thanks for your quick reply. Your examples help me a lot.
I'm now able to search by name or zip code, even with accents!! :wink:
Thanks again!! :slight_smile:
Patrice
