I'm trying to compute count of a nested field where active and inactive is not 0 for both values. But I can't get my aggs working inside the bucket_script. Initially I tried using the active_entities" : { "filter" but I i think it requires multi-bucket to work, so I switched it to filters filters. Ideally I'd like to use the original filter.
GET test/_search
"bool": {
"must": [
{"term": {"document_id.keyword": "1"}}
"size": 0,
"aggs": {
"entities" : {
"nested" : {"path" : "entities"},
"aggs" : {
"detected_entity_types" : {
"terms": { "field" : "entities.text.keyword" },
"aggs" : {
"entity_type" : { "terms": { "field": "entities.type.keyword" } },
"redaction_status" : {
"filters": {
"filters": {
"active" : { "match" : { "entities.redacted" : "true" }},
"inactive" : { "match" : { "entities.redacted" : "false" }}
,"count_not_eq": {
"bucket_script": {
"buckets_path": { "active": "redaction_status.active", "inactive": "redaction_status.inactive" },
"script": { "source": "logic here" }
// single bucket not working with bucket_script, needs multi-bucket filters filters?
//,"active_entities" : { "filter" : { "bool": {"must": [{"term": { "entities.redacted": true}}] }} }
//,"inactive_entities" : { "filter" : { "bool": {"must": [{"term": { "entities.redacted": false}}] }} }
Snippet of result
"aggregations" : {
"entities" : {
"doc_count" : 214,
"doc_count_error_upper_bound" : 0,
"sum_other_doc_count" : 160,
"buckets" : [
"key" : "2017",
"doc_count" : 8,
"entity_type" : {
"sum_other_doc_count" : 0,
"buckets" : [
"key" : "DATE",
"doc_count" : 8
"buckets" : {
"active" : {
"doc_count" : 0
"inactive" : {
"doc_count" : 8
