Need info regarding Kibana Timelion Remote Code Execution issue (ESA-2019-02)
I'm evaluating the Kibana Timelion Remote Code Execution issue (ESA-2019-02) CVE from:
I'd really appreciate if somebody could point out to the GitHub patch for this fix.
Thanks.
The PR for fixing this is here: https://github.com/elastic/kibana/pull/28834
Thanks @nickpeihl for your support on this.
Just to confirm, from what you say, ESA-2019-01 and ESA-2019-02 are both the same pull 28834?
@fragatina It appears to be the same PR for both. But you can email security@elastic.co for more info.
Thanks @nikpeihl for your help on this.
Hi, I am looking for the patch that's fixing the ESA-2019-01 XSSvulnerability. So Can we confirm that both ESA-2019-01 and ESA-2019-02 have the same PR's and Patches. Thanks in advance for the help
