Need input for ideal master and data node cluster for elastic search
Hi Team,
I am trying to deploy Elasticsearch version "8.7.0" and I am currently using "2.7.0" eck operator.
I need to deploy Elasticsearch in master-data architecture.
Could you please share the ideal(recommended) number of master and data node count that I can use for the configuration of Elasticsearch service.
Also, could you please share the recommended CPU requests that needs to be used for master and data pods .
Thanks and Regards,
Susmitha
Hi @susmithabadam1609
If you are just getting started with ECK I would highly highly recommend looking at
It is written by @Sunile_Manjee One of Our Opt Solutions Architects and is a great way to fast-track your ECK experience and knowledge.
thank you @stephenb ! @susmithabadam1609 ElasticKonductor is designed to help you launch a K8s instance on any cloud provider (AWS, Azure, GCP), preconfigured with node pools, labels, etc. It then installs ECK. It is highly configurable and driven by parameters.
