Thx Binh Ly,
You made a good point. But when I do not nest the facet it does not perform
the facet_filter correctly. This is my mapping without nesting:
"Product" : {
"properties" : {
"additionalShippingCharge" : {
"type" : "double"
"adminComment" : {
"type" : "string"
"allowBackInStockSubscriptions" : {
"type" : "boolean"
"allowCustomerReviews" : {
"type" : "boolean"
"allowedQuantities" : {
"type" : "string"
"approvedRatingSum" : {
"type" : "integer"
"approvedTotalReviews" : {
"type" : "integer"
"automaticallyAddRequiredProducts" : {
"type" : "boolean"
"availableEndDateTimeUtc" : {
"type" : "date",
"format" : "dateOptionalTime"
"availableForPreOrder" : {
"type" : "boolean"
"availableStartDateTimeUtc" : {
"type" : "date",
"backorderMode" : {
"type" : "long"
"backorderModeId" : {
"type" : "integer"
"callForPrice" : {
"type" : "boolean"
"categories" : {
"properties" : {
"allowCustomersToSelectPageSize" : {
"type" : "boolean"
"categoryTemplateId" : {
"type" : "integer"
"createdOnUtc" : {
"type" : "date",
"deleted" : {
"type" : "boolean"
"description" : {
"type" : "string"
"displayOrder" : {
"type" : "integer"
"hasDiscountsApplied" : {
"type" : "boolean"
"id" : {
"type" : "integer"
"includeInTopMenu" : {
"type" : "boolean"
"limitedToStores" : {
"type" : "boolean"
"metaDescription" : {
"type" : "string"
"metaKeywords" : {
"type" : "string"
"metaTitle" : {
"type" : "string"
"name" : {
"type" : "string",
"index" : "not_analyzed",
"norms" : {
"enabled" : false
"index_options" : "docs"
"pageSize" : {
"type" : "integer"
"pageSizeOptions" : {
"type" : "string"
"parentCategoryId" : {
"type" : "integer"
"pictureId" : {
"type" : "integer"
"priceRanges" : {
"type" : "string"
"published" : {
"type" : "boolean"
"seName" : {
"type" : "string",
"norms" : {
"enabled" : false
"showOnHomePage" : {
"type" : "boolean"
"subjectToAcl" : {
"type" : "boolean"
"updatedOnUtc" : {
"type" : "date",
"categoryIds" : {
"type" : "integer"
"createdOnUtc" : {
"type" : "date",
"customerEntersPrice" : {
"type" : "boolean"
"deleted" : {
"type" : "boolean"
"deliveryDateId" : {
"type" : "integer"
"disableBuyButton" : {
"type" : "boolean"
"disableWishlistButton" : {
"type" : "boolean"
"displayOrder" : {
"type" : "integer"
"displayStockAvailability" : {
"type" : "boolean"
"displayStockQuantity" : {
"type" : "boolean"
"downloadActivationType" : {
"type" : "long"
"downloadActivationTypeId" : {
"type" : "integer"
"downloadExpirationDays" : {
"type" : "integer"
"downloadId" : {
"type" : "integer"
"fullDescription" : {
"type" : "string"
"giftCardType" : {
"type" : "long"
"giftCardTypeId" : {
"type" : "integer"
"gtin" : {
"type" : "string"
"type" : "boolean"
"hasSampleDownload" : {
"type" : "boolean"
"hasTierPrices" : {
"type" : "boolean"
"hasUserAgreement" : {
"type" : "boolean"
"height" : {
"type" : "double"
"id" : {
"type" : "integer"
"imageUrl" : {
"type" : "string",
"norms" : {
"enabled" : false
"isDownload" : {
"type" : "boolean"
"isFreeShipping" : {
"type" : "boolean"
"isGiftCard" : {
"type" : "boolean"
"isRecurring" : {
"type" : "boolean"
"isShipEnabled" : {
"type" : "boolean"
"isTaxExempt" : {
"type" : "boolean"
"length" : {
"type" : "double"
"type" : "boolean"
"lowStockActivity" : {
"type" : "long"
"lowStockActivityId" : {
"type" : "integer"
"manageInventoryMethod" : {
"type" : "long"
"manageInventoryMethodId" : {
"type" : "integer"
"manufacturerIds" : {
"type" : "integer"
"manufacturerPartNumber" : {
"type" : "string"
"manufacturers" : {
"properties" : {
"type" : "boolean"
"createdOnUtc" : {
"type" : "date",
"deleted" : {
"type" : "boolean"
"description" : {
"type" : "string"
"displayOrder" : {
"type" : "integer"
"id" : {
"type" : "integer"
"type" : "boolean"
"manufacturerTemplateId" : {
"type" : "integer"
"type" : "string"
"metaKeywords" : {
"type" : "string"
"metaTitle" : {
"type" : "string"
"name" : {
"type" : "string",
"norms" : {
"enabled" : false
"pageSize" : {
"type" : "integer"
"type" : "string"
"pictureId" : {
"type" : "integer"
"priceRanges" : {
"type" : "string"
"published" : {
"type" : "boolean"
"seName" : {
"type" : "string",
"norms" : {
"enabled" : false
"subjectToAcl" : {
"type" : "boolean"
"updatedOnUtc" : {
"type" : "date",
"maxNumberOfDownloads" : {
"type" : "integer"
"maximumCustomerEnteredPrice" : {
"type" : "double"
"type" : "string"
"metaKeywords" : {
"type" : "string"
"metaTitle" : {
"type" : "string"
"minStockQuantity" : {
"type" : "integer"
"minimumCustomerEnteredPrice" : {
"type" : "double"
"name" : {
"type" : "string"
"notApprovedRatingSum" : {
"type" : "integer"
"notApprovedTotalReviews" : {
"type" : "integer"
"notifyAdminForQuantityBelow" : {
"type" : "integer"
"oldPrice" : {
"type" : "double"
"orderMaximumQuantity" : {
"type" : "integer"
"orderMinimumQuantity" : {
"type" : "integer"
"parentGroupedProductId" : {
"type" : "integer"
"preOrderAvailabilityStartDateTimeUtc" : {
"type" : "date",
"price" : {
"type" : "double"
"productAttributeOptionIds" : {
"type" : "integer"
"productAttributes" : {
"properties" : {
"filterAttributeOptions" : {
"properties" : {
"count" : {
"type" : "integer"
"filterAttributeId" : {
"type" : "integer"
"id" : {
"type" : "integer"
"isActive" : {
"type" : "boolean"
"name" : {
"type" : "string",
"norms" : {
"enabled" : false
"id" : {
"type" : "integer"
"isVisible" : {
"type" : "boolean"
"name" : {
"type" : "string",
"norms" : {
"enabled" : false
"productCost" : {
"type" : "double"
"productTemplateId" : {
"type" : "integer"
"productType" : {
"type" : "long"
"productTypeId" : {
"type" : "integer"
"published" : {
"type" : "boolean"
"recurringCycleLength" : {
"type" : "integer"
"recurringCyclePeriod" : {
"type" : "long"
"recurringCyclePeriodId" : {
"type" : "integer"
"recurringTotalCycles" : {
"type" : "integer"
"requireOtherProducts" : {
"type" : "boolean"
"requiredProductIds" : {
"type" : "string"
"sampleDownloadId" : {
"type" : "integer"
"seName" : {
"type" : "string",
"norms" : {
"enabled" : false
"shortDescription" : {
"type" : "string"
"type" : "boolean"
"sku" : {
"type" : "string"
"specialPrice" : {
"type" : "double"
"specialPriceEndDateTimeUtc" : {
"type" : "date",
"specialPriceStartDateTimeUtc" : {
"type" : "date",
"specificationAttributeOptionIds" : {
"type" : "integer"
"specificationAttributes" : {
"properties" : {
"properties" : {
"count" : {
"type" : "integer"
"type" : "integer"
"id" : {
"type" : "integer"
"isActive" : {
"type" : "boolean"
"name" : {
"type" : "string",
"norms" : {
"enabled" : false
"id" : {
"type" : "integer"
"isVisible" : {
"type" : "boolean"
"name" : {
"type" : "string",
"norms" : {
"enabled" : false
"stockQuantity" : {
"type" : "integer"
"subjectToAcl" : {
"type" : "boolean"
"taxCategoryId" : {
"type" : "integer"
"unlimitedDownloads" : {
"type" : "boolean"
"updatedOnUtc" : {
"type" : "date",
"userAgreementText" : {
"type" : "string"
"vendorId" : {
"type" : "integer"
"visibleIndividually" : {
"type" : "boolean"
"warehouseId" : {
"type" : "integer"
"weight" : {
"type" : "double"
"width" : {
"type" : "double"
But now my facet filter does not work. It gives all terms without filtering
on the filterAttributeId:
"from": 0,
"size": 30,
"sort": {
"oldPrice": "asc",
"createdOnUtc": "desc"
"facets": {
"Manufacturers": {
"terms": {
"field": "manufacturers.name",
"size": 500
"Color": {
"terms": {
"field": "specificationAttributes.filterAttributeOptions.name",
"size": 500
"facet_filter": {
"specificationAttributes.filterAttributeOptions.filterAttributeId": [*
"1"*
"bool": {
"must": [
"term": {
"published": {
"value": true
"term": {
"deleted": {
"value": false
"terms": {
"categoryIds": [
"2",
"57",
"23",
"61",
"25",
"26",
"27",
"62",
"28",
"29",
"30",
"31",
"54",
"33",
"32",
"24"
Op vrijdag 4 april 2014 22:52:06 UTC+2 schreef Binh Ly:
Don't know if this matters to you but if you do a nested in a facet, then
the facet_filter in it only applies to the nested object. Is it possible
that you didn't intend that facet_filter to execute on the nested object?
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/10bae3dc-dc32-4e93-9f23-002f18be88b4%40googlegroups.com.
