NiFi flow not able to write into Elasticsearch because of exceeding maximum shards
I have only one node elasticsearch at my cluster. I'm trying to write into elasticsearch using PutElasticsearchHttp control at my NiFi flow but I get an error:
2023-05-24 07:00:17,347 ERROR [Timer-Driven Process Thread-3] o.a.n.p.e.PutElasticsearchHttp PutElasticsearchHttp[id=237111a5-14ab-143f-4e7b-56c0b4bd3a05] Failed to process StandardFlowFileRecord[uuid=e540a2d7-0783-43e4-a07c-8005f8d086ac,claim=StandardContentClaim [resourceClaim=StandardResourceClaim[id=1684911617322-2727, container=default, section=679], offset=9083, length=633],offset=0,name=d273874a-3273-486f-8b78-9e7d0f923ed2,size=633] due to
Validation Failed: 1: this action would add [2] total shards, but this cluster currently has [999]/[1000] maximum shards open;, transferring to failure
when I checked _cluster/stats, I got only 509 shards while error is 999 shards which I do not have! are there more shards not shown? how to control this to avoid such issues while importing data using different tools?
  "_nodes" : {
    "total" : 1,
    "successful" : 1,
    "failed" : 0
  "cluster_name" : "docker-cluster",
  "cluster_uuid" : "0lpL8vheSdeFYpfQmbb9uw",
  "timestamp" : 1684922893105,
  "status" : "yellow",
  "indices" : {
    "count" : 509,
    "shards" : {
      "total" : 509,
      "primaries" : 509,
      "replication" : 0.0,
      "index" : {
        "shards" : {
          "min" : 1,
          "max" : 1,
          "avg" : 1.0
        "primaries" : {
          "min" : 1,
          "max" : 1,
          "avg" : 1.0
        "replication" : {
          "min" : 0.0,
          "max" : 0.0,
          "avg" : 0.0
    "docs" : {
      "count" : 619613169,
      "deleted" : 684
    "store" : {
      "size_in_bytes" : 855924263210,
      "reserved_in_bytes" : 0
    "fielddata" : {
      "memory_size_in_bytes" : 2112,
      "evictions" : 0
    "query_cache" : {
      "memory_size_in_bytes" : 0,
      "total_count" : 0,
      "hit_count" : 0,
      "miss_count" : 0,
      "cache_size" : 0,
      "cache_count" : 0,
      "evictions" : 0
    "completion" : {
      "size_in_bytes" : 0
    "segments" : {
      "count" : 4474,
      "memory_in_bytes" : 45867042,
      "terms_memory_in_bytes" : 37245464,
      "stored_fields_memory_in_bytes" : 2569120,
      "term_vectors_memory_in_bytes" : 0,
      "norms_memory_in_bytes" : 5289792,
      "points_memory_in_bytes" : 0,
      "doc_values_memory_in_bytes" : 762666,
      "index_writer_memory_in_bytes" : 2986552,
      "version_map_memory_in_bytes" : 0,
      "fixed_bit_set_memory_in_bytes" : 1216,
      "max_unsafe_auto_id_timestamp" : 1684912919948,
      "file_sizes" : { }
    "mappings" : {
      "field_types" : [
          "name" : "binary",
          "count" : 15,
          "index_count" : 4
          "name" : "boolean",
          "count" : 51,
          "index_count" : 14
          "name" : "byte",
          "count" : 4,
          "index_count" : 4
          "name" : "date",
          "count" : 1003,
          "index_count" : 476
          "name" : "date_nanos",
          "count" : 1,
          "index_count" : 1
          "name" : "date_range",
          "count" : 1,
          "index_count" : 1
          "name" : "double",
          "count" : 1,
          "index_count" : 1
          "name" : "double_range",
          "count" : 1,
          "index_count" : 1
          "name" : "flattened",
          "count" : 9,
          "index_count" : 1
          "name" : "float",
          "count" : 4,
          "index_count" : 2
          "name" : "float_range",
          "count" : 1,
          "index_count" : 1
          "name" : "geo_point",
          "count" : 1,
          "index_count" : 1
          "name" : "geo_shape",
          "count" : 1,
          "index_count" : 1
          "name" : "half_float",
          "count" : 1,
          "index_count" : 1
          "name" : "integer",
          "count" : 30,
          "index_count" : 4
          "name" : "integer_range",
          "count" : 1,
          "index_count" : 1
          "name" : "ip",
          "count" : 1,
          "index_count" : 1
          "name" : "ip_range",
          "count" : 1,
          "index_count" : 1
          "name" : "keyword",
          "count" : 10165,
          "index_count" : 507
          "name" : "long",
          "count" : 37,
          "index_count" : 15
          "name" : "long_range",
          "count" : 1,
          "index_count" : 1
          "name" : "nested",
          "count" : 11,
          "index_count" : 6
          "name" : "object",
          "count" : 212,
          "index_count" : 22
          "name" : "shape",
          "count" : 1,
          "index_count" : 1
          "name" : "short",
          "count" : 7,
          "index_count" : 4
          "name" : "text",
          "count" : 9884,
          "index_count" : 504
    "analysis" : {
      "char_filter_types" : [ ],
      "tokenizer_types" : [ ],
      "filter_types" : [
          "name" : "pattern_capture",
          "count" : 1,
          "index_count" : 1
      "analyzer_types" : [
          "name" : "custom",
          "count" : 1,
          "index_count" : 1
      "built_in_char_filters" : [ ],
      "built_in_tokenizers" : [
          "name" : "uax_url_email",
          "count" : 1,
          "index_count" : 1
      "built_in_filters" : [
          "name" : "lowercase",
          "count" : 1,
          "index_count" : 1
          "name" : "unique",
          "count" : 1,
          "index_count" : 1
      "built_in_analyzers" : [ ]
  "nodes" : {
    "count" : {
      "total" : 1,
      "coordinating_only" : 0,
      "data" : 1,
      "data_cold" : 1,
      "data_content" : 1,
      "data_hot" : 1,
      "data_warm" : 1,
      "ingest" : 1,
      "master" : 1,
      "ml" : 1,
      "remote_cluster_client" : 1,
      "transform" : 1,
      "voting_only" : 0
    "versions" : [
      "7.10.1"
    "os" : {
      "available_processors" : 4,
      "allocated_processors" : 4,
      "names" : [
          "name" : "Linux",
          "count" : 1
      "pretty_names" : [
          "pretty_name" : "CentOS Linux 8 (Core)",
          "count" : 1
      "mem" : {
        "total_in_bytes" : 25111343104,
        "free_in_bytes" : 252829696,
        "used_in_bytes" : 24858513408,
        "free_percent" : 1,
        "used_percent" : 99
    "process" : {
      "cpu" : {
        "percent" : 0
      "open_file_descriptors" : {
        "min" : 5727,
        "max" : 5727,
        "avg" : 5727
    "jvm" : {
      "max_uptime_in_millis" : 10005104,
      "versions" : [
          "version" : "15.0.1",
          "vm_name" : "OpenJDK 64-Bit Server VM",
          "vm_version" : "15.0.1+9",
          "vm_vendor" : "AdoptOpenJDK",
          "bundled_jdk" : true,
          "using_bundled_jdk" : true,
          "count" : 1
      "mem" : {
        "heap_used_in_bytes" : 1840046080,
        "heap_max_in_bytes" : 4294967296
      "threads" : 114
    "fs" : {
      "total_in_bytes" : 2413785710592,
      "free_in_bytes" : 1421521993728,
      "available_in_bytes" : 1323284590592
    "plugins" : [ ],
    "network_types" : {
      "transport_types" : {
        "security4" : 1
      "http_types" : {
        "security4" : 1
    "discovery_types" : {
      "single-node" : 1
    "packaging_types" : [
        "flavor" : "default",
        "type" : "docker",
        "count" : 1
    "ingest" : {
      "number_of_pipelines" : 1,
      "processor_stats" : {
        "gsub" : {
          "count" : 0,
          "failed" : 0,
          "current" : 0,
          "time_in_millis" : 0
        "script" : {
          "count" : 0,
          "failed" : 0,
          "current" : 0,
You have replicas configured, which can never be allocated on a single node cluster. I would therefore recommend you update or create an index template to set the number of replicas to 0. You can then also change index settings for existing indices and set the number of replicas to 0 for these as well. It looks like you are creating a large number of quite small indices which is inefficient so you may want to look into changing how you shard data to get a larger average shard size.
"You have replicas configured, which can never be allocated on a single node cluster"
but why not showing at _cluster/stats
I get:
"shards" : {
      "total" : 509,
      "primaries" : 509,
      "replication" : 0.0
while error is for 999 shards and failed because of extra 2 while max seems 1000!
If I remember correctly it does take replicas into account even if they can never be allocated. Making that change will not hurt anyway and may resolve the issue.
