Hi there,
I have a test server running that I can only access via ssh.
Therefore, I tunneled the 9300 port to my localhost.
The nodeClient in the JavaAPI somehow can find my masternode but not
connect after timeout of 30s.
Any ideas? Help!
2015-01-28T15:34:33.651+0100|Information: 2015.01.28_15:34:33,651 - DEBUG
org.elasticsearch.discovery.zen: [LT356.41c6fb63] filtered ping responses: (
filter_client[true], filter_data[false])
--> ping_response{node [[centralnode][TxdaBxULSK6Rr1obILiP_A][ritab2v05
][inet[/161.50.140.3:9300]]{bench=true}], id[306], master
[[centralnode][TxdaBxULSK6Rr1obILiP_A][ritab2v05][inet[/161.50.140.3:9300]]{bench=true}],
hasJoinedOnce [true], cluster_name[elasticsearch-test]}
[Thread=elasticsearch[LT356.41c6fb63][generic][T#5]]
2015-01-28T15:34:54.663+0100|Information: 2015.01.28_15:34:54,662 - WARN
org.elasticsearch.discovery.zen: [LT356.41c6fb63] failed to connect to
master
retrying... [Thread=elasticsearch[LT356.41c6fb63][generic][T#5]]
org.elasticsearch.transport.ConnectTransportException:
[centralnode][inet[/161.50.140.3:9300]] connect_timeout[30s]
at
org.elasticsearch.transport.netty.NettyTransport.connectToChannels(NettyTransport.java:807)
at
org.elasticsearch.transport.netty.NettyTransport.connectToNode(NettyTransport.java:741)
at
org.elasticsearch.transport.netty.NettyTransport.connectToNode(NettyTransport.java:714)
at
org.elasticsearch.transport.TransportService.connectToNode(TransportService.java:150)
at
org.elasticsearch.discovery.zen.ZenDiscovery.joinElectedMaster(ZenDiscovery.java:441)
at
org.elasticsearch.discovery.zen.ZenDiscovery.innerJoinCluster(ZenDiscovery.java:393)
at
org.elasticsearch.discovery.zen.ZenDiscovery.access$6000(ZenDiscovery.java:80)
at
org.elasticsearch.discovery.zen.ZenDiscovery$JoinThreadControl$1.run(ZenDiscovery.java:1318)
at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
Caused by: java.net.ConnectException: Connection timed out: no further
information: /161.50.140.3:9300
at sun.nio.ch.SocketChannelImpl.checkConnect(Native Method)
at sun.nio.ch.SocketChannelImpl.finishConnect(SocketChannelImpl.java:739
at org.elasticsearch.common.netty.channel.socket.nio.NioClientBoss.
connect(NioClientBoss.java:152)
processSelectedKeys(NioClientBoss.java:105)
process(NioClientBoss.java:79)
at org.elasticsearch.common.netty.channel.socket.nio.AbstractNioSelector
.run(AbstractNioSelector.java:318)
at org.elasticsearch.common.netty.channel.socket.nio.NioClientBoss.run(
NioClientBoss.java:42)
at org.elasticsearch.common.netty.util.ThreadRenamingRunnable.run(
ThreadRenamingRunnable.java:108)
at org.elasticsearch.common.netty.util.internal.DeadLockProofWorker$1.
run(DeadLockProofWorker.java:42)
... 3 more
2015-01-28T15:34:54.667+0100|Information: 2015.01.28_15:34:54,667 - DEBUG
org.elasticsearch.cluster.service: [LT356.41c6fb63] processing [finalize_join
([centralnode][TxdaBxULSK6Rr1obILiP_A][ritab2v05][inet[/161.50.140.3:9300]]{
bench=true})]: execute [Thread=elasticsearch[LT356.41c6fb63][clusterService
#updateTask][T#1]]
2015-01-28T15:34:54.668+0100|Information: 2015.01.28_15:34:54,668 - DEBUG
bench=true})]: no change in cluster_state [Thread=elasticsearch[LT356.
41c6fb63][clusterService#updateTask][T#1]]
2015-01-28T15:34:54.681+0100|Information: 2015.01.28_15:34:54,680 - DEBUG
org.elasticsearch.transport.netty: [LT356.41c6fb63] connected to node [[#zen_unicast_1#][LT356][inet[localhost/127.0.0.1:9300]]]
[Thread=elasticsearch[LT356.41c6fb63][[unicast_connect]][T#1]]
2015-01-28T15:34:57.687+0100|Information: 2015.01.28_15:34:57,687 - DEBUG
org.elasticsearch.transport.netty: [LT356.41c6fb63] disconnecting from [[#zen_unicast_1#][LT356][inet[localhost/127.0.0.1:9300]]]
due to explicit disconnect call
[Thread=elasticsearch[LT356.41c6fb63][generic][T#1]]
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/9e45fa37-c17e-4d93-afa0-1c447bc6aaf2%40googlegroups.com.
