Not able to import data into index after applying custom analyzer and proper mapping [Re-Posting-it]
i want to use ngram tokenizer for searching any substring in a word
this is custom analyzer code is
         "analysis" => [
            "analyzer"  => [
                "ngram_analyzer"    => [
                    "type" => "custom",
                    "tokenizer" => "ngram_tokenizer",
            "tokenizer" =>  [
                "ngram_tokenizer"  =>  [
                    "type"  =>  "ngram",
                    "min_gram"    =>  3,
                    "max_gram"    =>  10,
                    "token_chars" =>  [
                        "letter",
                        "digit"
and these are the fields i want to apply analyzer on
   "mappings"  =>   [
        "orders"    =>   [
            "properties"    =>   [
                "account_title" =>   [
                    "type"  =>   "string",
                    "analyzer"  =>  "ngram_analyzer",
                "address1"    =>   [
                    "type"  =>   "string",
               "buyer_id"    =>   [
                    "type"  =>   "long"
               "cost"    =>   [
                    "type"  =>   "float"
when i try to bulk import data into this elasticsearch index nothing is added .. without custom analyzer everything is working fine but with custom analyzer i am not getting any error and data is also not added into elasticsearch index.
[] == {} so ignore brackets ..
Thanks in advance
can you please provide a full reproduction using curl or sense syntax so others can reproduce? This includes index creation, mapping configuration, sample indexing of documents.
Thanks!
Thank you for your reply
i fixed it myself ..
