Offline plugin installation problem
I created logstash-offline-plugins zip file for email output plugin with Logstash 5.3.0
Zip file contains
-logstash folder
--dependencies
---mail-2.6.4.gem
---mime-types-2.6.2.gem
--logstash-output-email-4.0.3.gem
When I try to install it offline server, I'm getting this error message
"Could not find gem 'logstash-output-email (= 4.0.3) java' in any of the gem sources listed in your Gemfile or installed on this machine."
Hello @mevbas, did you use the prepare-offline-pack subcommand to generate the zip?
Using Logstash 5.3.0, I was able to do the following:
  • install the logstash-output-email
  • bin/logstash-plugin prepare-offline-pack logstash-output-email
  • turn off internet
  • bin/logstash-plugin install file:///tmp/logstash-offline-plugins-5.3.0.zip
✘ph@sashimi~/es/stable_releases/logstash-5.3.0 bin/logstash-plugin list --verbose email        ⏎
logstash-output-email (4.0.3)
