Hi All,
We want to run two ES nodes(one is data node and other one is client node)
on one machine. Both the node pointing on same data location.
If my data node goes down, my query will not return any result, even my
client node is running.
How we can point two ES nodes on one data location, and also if one node
goes down, the second node will take the position of first node?
Thanks,
Ankit
