Hello
We have following issue after enabling log collection by elastic agent
with system v1.54.0 integration
We ship logs to logstash and then to ES. ES pipeline logs-system.syslog-1.54.0 tries to grok field message, but when I output to file from logstash, logs from elastic agents(for system.syslog) don't have this field, they only have event.original.
Grok section of logs-system.syslog pipeline
    "grok": {
      "field": "message",
      "patterns": [
        "%{SYSLOGTIMESTAMP:system.syslog.timestamp} %{SYSLOGHOST:host.hostname} %{DATA:process.name}(?:\\[%{POSINT:process.pid:long}\\])?: %{GREEDYMULTILINE:system.syslog.message}",
        "%{SYSLOGTIMESTAMP:system.syslog.timestamp} %{GREEDYMULTILINE:system.syslog.message}",
        "%{TIMESTAMP_ISO8601:system.syslog.timestamp} %{SYSLOGHOST:host.hostname} %{DATA:process.name}(?:\\[%{POSINT:process.pid:long}\\])?: %{GREEDYMULTILINE:system.syslog.message}"
      "pattern_definitions": {
        "GREEDYMULTILINE": "(.|\n)*"
      "ignore_missing": true
Example log (file output from logstash)
	"input": {
		"type": "log"
	"agent": {
		"version": "8.12.1",
		"name": "FOO-BAR",
		"ephemeral_id": "3ac98aba-dd7c-4bf9-ab1e-e1df821a2c21",
		"id": "5082c6d4-5539-406d-92a7-7f5f24bf9e31",
		"type": "filebeat"
	"@version": "1",
	"elastic_agent": {
		"snapshot": false,
	"host": {
		"ip": [
			"fe80::ecee:eeff:feee:eeee"
		"containerized": false,
		"id": "1f093cab5e0f4556b431be1e432376aa",
		"os": {
			"kernel": "5.10.0-21-amd64",
			"version": "11 (bullseye)",
			"name": "Debian GNU/Linux",
			"type": "linux",
			"codename": "bullseye",
			"platform": "debian",
			"family": "debian"
		"mac": [
			"EE-EE-EE-EE-EE-EE"
		"architecture": "x86_64",
		"name": "FOO-BAR",
		"hostname": "FOO-BAR"
	"data_stream": {
		"dataset": "system.syslog",
		"type": "logs",
		"namespace": "default"
	"tags": [
		"beats_input_codec_plain_applied",
	"@timestamp": "2024-03-19T13:24:05.274Z",
	"ecs": {
		"version": "8.0.0"
	"event": {
		"original": "Mar 19 14:24:05 FOO-BAR REMOVED",
		"timezone": "+01:00"
	"log": {
		"offset": 272868660,
		"file": {
			"path": "/var/log/messages"
		"logger": "FOO-BAR"
This can be worked around by following filter in logstash, but should agent not use message or pipeline event.original field?
  if [event][dataset] == "system.syslog" {
    mutate {
      copy => { "[event][original]" => "[message]" }
      id => "mutate_syslog_b2"
