Possible values for "Phase" field for elasticSearch resource
After an Elasticsearch instance is created, I do a kubectl get Elasticsearch to get the status and I get the following output:
NAME      HEALTH   NODES   VERSION   PHASE   AGE
quickstart green    3       7.11.2    Ready   17h
As you see the Phase is "Ready"
What are the other possible values for the fields Health and Phase?
Hi @x00m, thanks for your question.
The possible values are below and the relevant source code is available as well.
	// ElasticsearchReadyPhase is operating at the desired spec.
	ElasticsearchReadyPhase ElasticsearchOrchestrationPhase = "Ready"
	// ElasticsearchApplyingChangesPhase controller is working towards a desired state, cluster can be unavailable.
	ElasticsearchApplyingChangesPhase ElasticsearchOrchestrationPhase = "ApplyingChanges"
	// ElasticsearchMigratingDataPhase Elasticsearch is currently migrating data to another node.
	ElasticsearchMigratingDataPhase ElasticsearchOrchestrationPhase = "MigratingData"
	// ElasticsearchResourceInvalid is marking a resource as invalid, should never happen if admission control is installed correctly.
	ElasticsearchResourceInvalid ElasticsearchOrchestrationPhase = "Invalid"
Thanks,
David
