Hi everyone,
I am currently developing a little project for university essay with educational purposes.
In this project, I'm trying to use rabbit mq to send Log messages to Logstash from a Spring Boot Backend. Currently, the Logstash container Logs indicate error when resolving the ES service.
[2022-12-08T11:11:12,649][WARN ][logstash.licensechecker.licensereader] Attempted to resurrect connection to dead ES instance, but got an error {:url=>"http://localhost:9200/", :exception=>LogStash::Outputs::Elasticsearch::HttpClient::Pool::HostUnreachableError, :message=>"Elasticsearch Unreachable: [http://localhost:9200/][Manticore::SocketException] Connect to localhost:9200 [localhost/127.0.0.1] failed: Connection refused"}
In no place I say that the ES is running on localhost, and before using Rabbit MQ the same output worked from a TCP input from the Spring Boot backend.
Here is my LogStash conf file:
rabbitmq {
subscription_retry_interval_seconds => 2
automatic_recovery => true
connect_retry_interval => 3
durable => true
exchange => "EnterpriseApplicationLog"
exchange_type => "topic"
key => ""
host => "rabbitmq"
vhost => "/"
queue => "ApplicationLog"
port => 5672
user => "guest"
password => "guest"
passive => false
prefetch_count => 10
threads => 1
ack => true
# type => "Log"
action => "index"
codec => "json"
hosts => ["elasticsearch"]
index => "logstash-%{+YYYY.MM.dd}"
DockerCompose file:
version: "3"
services:
db:
image: postgres:15.1-alpine
restart: always
environment:
- POSTGRES_USER=postgres
- POSTGRES_PASSWORD=postgres
ports:
- '5432:5432'
volumes:
- ./db-data:/var/lib/postgresql/data
# copy the sql script to create tables
- ./bd.sql:/docker-entrypoint-initdb.d/create_tables.sql
networks:
- appreservas
rabbitmq:
image: rabbitmq:3-management-alpine
container_name: 'rabbitmq'
ports:
- 5672:5672
- 15672:15672
volumes:
- ~/.docker-conf/rabbitmq/data/:/var/lib/rabbitmq/
- ~/.docker-conf/rabbitmq/log/:/var/log/rabbitmq
networks:
- appreservas
elasticsearch:
image: docker.elastic.co/elasticsearch/elasticsearch:8.5.2
container_name: elasticsearch_springboot
environment:
- bootstrap.memory_lock=true
- "ES_JAVA_OPTS=-Xms512m -Xmx512m"
- "discovery.type=single-node"
- xpack.security.enabled=false
ports:
- "9200:9200"
volumes:
- elasticsearch_data:/usr/share/elasticsearch/data
networks:
- appreservas
kibana:
image: docker.elastic.co/kibana/kibana:8.5.2
container_name: kibana_springboot
ports:
- "5601:5601"
environment:
ELASTICSEARCH_URL: http://elasticsearch:9200
ELASTICSEARCH_HOSTS: '["http://elasticsearch:9200"]'
depends_on:
- elasticsearch
networks:
- appreservas
logstash:
image: docker.elastic.co/logstash/logstash:8.5.2
container_name: logstash_springboot
volumes:
- ./logstash/config/logstash.yml:/usr/share/logstash/config/logstash.yml:ro
- ./logstash/pipeline:/usr/share/logstash/pipeline:ro
ports:
- "5044:5044"
- "5000:5000/tcp"
- "5000:5000/udp"
- "9600:9600"
environment:
LS_JAVA_OPTS: "-Xmx256m -Xms256m"
RABBIT_MQ_IP: "rabbitmq"
networks:
- appreservas
depends_on:
- elasticsearch
- rabbitmq
auth-backend:
build:
context: ./auth
ports:
- '8085:8085'
environment:
- SPRING_DATASOURCE_URL=jdbc:postgresql://db:5432/appreservas?currentSchema=auth
- LOGSTASH_URL=logstash:5000
- RABBIT_MQ_IP=rabbitmq
depends_on:
- db
- logstash
- rabbitmq
networks:
- appreservas
volumes:
db:
driver: local
elasticsearch_data:
driver: local
elastic_data: {}
networks:
appreservas:
Thanks in advance!
