Problem in converting string to ip
Hi i tried to convert string to ip by following the steps provided in the threads but its not working for me. I am getting following error on starting kibana.
08:24:50.444 [[main]-pipeline-manager] INFO logstash.outputs.elasticsearch - Installing elasticsear
ch template to _template/logstash
08:24:50.486 [[main]-pipeline-manager] ERROR logstash.outputs.elasticsearch - Failed to install temp
late. {:message=>"Got response code '400' contact Elasticsearch at URL 'http://localhost:9200/_templ
ate/logstash'", :class=>"LogStash::Outputs::ElasticSearch::HttpClient::Pool::BadResponseCodeError"}
08:24:50.488 [[main]-pipeline-manager] INFO logstash.outputs.elasticsearch - New Elasticsearch outp
ut {:class=>"LogStash::Outputs::ElasticSearch", :hosts=>["localhost:9200"]}
i did created a template.json as below with ip type mentioned.
"template": "logstash-",
"settings" : {
"number_of_shards" : 1,
"number_of_replicas" : 0,
"index" : {
"query" : { "default_field" : "@message" },
"store" : { "compress" : { "stored" : true, "tv": true } }
"mappings": {
"default": {
"_all": { "enabled": false },
"_source": { "compress": true },
"dynamic_templates": [
"string_template" : {
"match" : "
"mapping": { "type": "string", "index": "not_analyzed" },
"match_mapping_type" : "string"
"properties" : {
"@fields": { "type": "object", "dynamic": true, "path": "full" },
"@message" : { "type" : "string", "index" : "analyzed" },
"@source" : { "type" : "string", "index" : "not_analyzed" },
"@source_host" : { "type" : "string", "index" : "not_analyzed" },
"@source_path" : { "type" : "string", "index" : "not_analyzed" },
"@tags": { "type": "string", "index" : "not_analyzed" },
"@timestamp" : { "type" : "date", "index" : "not_analyzed" },
"@type" : { "type" : "string", "index" : "not_analyzed" },
"ipAddress" : {"type" : "ip"}
mentioned following in the output
stdout { codec => "json" }
elasticsearch{
hosts => ["localhost:9200"]
template => "C:/satish/satish/template.json"
template_overwrite => true
codec => "json"
index => "logstash-%{secEventType}"
can you help me in resolving this issue?
I'm surprised there isn't any better error messages in the Logstash log. Have you looked for more clues in the Elasticsearch log?
Hi magnus,
i didn't get any info in Elasticsearch log.
This is the complete log of logstash from console
08:24:50.251 [[main]-pipeline-manager] INFO logstash.outputs.elasticsearch - Elasticsearch pool URL
s updated {:changes=>{:removed=>, :added=>["http://localhost:9200"]}}
08:24:50.255 [[main]-pipeline-manager] INFO logstash.outputs.elasticsearch - Running health check t
o see if an Elasticsearch connection is working {:url=>#<URI::HTTP:0x68930d0f URL:http://localhost:9
200>, :healthcheck_path=>"/"}
08:24:50.388 [[main]-pipeline-manager] WARN logstash.outputs.elasticsearch - Restored connection to
ES instance {:url=>#<URI::HTTP:0x68930d0f URL:http://localhost:9200>}
08:24:50.389 [[main]-pipeline-manager] INFO logstash.outputs.elasticsearch - Using mapping template
from {:path=>"C:/satish/satish/template.json"}
08:24:50.438 [[main]-pipeline-manager] INFO logstash.outputs.elasticsearch - Attempting to install
template {:manage_template=>{"template"=>"logstash-", "settings"=>{"number_of_shards"=>1, "number_o
f_replicas"=>0, "index"=>{"query"=>{"default_field"=>"@message"}, "store"=>{"compress"=>{"stored"=>t
rue, "tv"=>true}}}}, "mappings"=>{"default"=>{"_all"=>{"enabled"=>false}, "_source"=>{"compress"=>
true}, "dynamic_templates"=>[{"string_template"=>{"match"=>"
", "mapping"=>{"type"=>"string", "index
"=>"not_analyzed"}, "match_mapping_type"=>"string"}}], "properties"=>{"@fields"=>{"type"=>"object",
"dynamic"=>true, "path"=>"full"}, "@message"=>{"type"=>"string", "index"=>"analyzed"}, "@source"=>{"
type"=>"string", "index"=>"not_analyzed"}, "@source_host"=>{"type"=>"string", "index"=>"not_analyzed
"}, "@source_path"=>{"type"=>"string", "index"=>"not_analyzed"}, "@tags"=>{"type"=>"string", "index"
=>"not_analyzed"}, "@timestamp"=>{"type"=>"date", "index"=>"not_analyzed"}, "@type"=>{"type"=>"strin
g", "index"=>"not_analyzed"}, "ipAddress"=>{"type"=>"ip"}}}}}}
ate/logstash'", :class=>"LogStash::Outputs::Elasticsearch::HttpClient::Pool::BadResponseCodeError"}
ut {:class=>"LogStash::Outputs::Elasticsearch", :hosts=>["localhost:9200"]}
08:24:50.491 [[main]-pipeline-manager] INFO logstash.pipeline - Starting pipeline {"id"=>"main", "p
ipeline.workers"=>4, "pipeline.batch.size"=>125, "pipeline.batch.delay"=>5, "pipeline.max_inflight"=
500}
08:24:50.496 [[main]-pipeline-manager] INFO logstash.pipeline - Pipeline main started
{"ipaddress":"169.254.133.10","secEventType":"authentication","messageID":"messageID0","userName":"u
serName0","Info":"Info0","tags":["_dateparsefailure"],"timeStamp":"Tue 2017 Jan 24, 02:36:31:088","p
ath":"C:/satish/SecurityEvent-2017-Jan-24.log","@timestamp":"2017-01-24T02:54:50.239Z","info1":"abc0
","@version":"1","host":"L24660WIN","ID":"000891b7-1907-40ed-a1d5-d0a51be07ad3","info2":"xyz0"}{"ipa
ddress":"169.254.133.10","secEventType":"dataaccess","messageID":"messageID1","userName":"userName1"
,"Info":"Info1","tags":["_dateparsefailure"],"timeStamp":"Tue 2017 Jan 24, 02:36:31:089","path":"C:/
satish/SecurityEvent-2017-Jan-24.log","@timestamp":"2017-01-24T02:54:50.501Z","info1":"abc1","@versi
on":"1","host":"L24660WIN","ID":"ffd1a034-022e-44a5-9aa0-0f9312db8b38","info2":"xyz1"}{"ipaddress":"
169.254.133.10","secEventType":"authentication","messageID":"messageID2","userName":"userName2","Inf
o":"Info2","tags":["_dateparsefailure"],"timeStamp":"Tue 2017 Jan 24, 02:36:31:089","path":"C:/satis
h/SecurityEvent-2017-Jan-24.log","@timestamp":"2017-01-24T02:54:50.503Z","info1":"abc2","@version":"
1","host":"L24660WIN","ID":"62331fcc-562b-4bd8-9c5f-b80a860b02ed","info2":"xyz2"}{"ipaddress":"169.2
54.133.10","secEventType":"dataaccess","messageID":"messageID3","userName":"userName3","Info":"Info3
","tags":["_dateparsefailure"],"timeStamp":"Tue 2017 Jan 24, 02:36:31:089","path":"C:/satish/Securit
yEvent-2017-Jan-24.log","@timestamp":"2017-01-24T02:54:50.506Z","info1":"abc3","@version":"1","host"
:"L24660WIN","ID":"7bca07ca-cbbf-42ae-b085-0ba1ec2cc7d0","info2":"xyz3"}{"ipaddress":"169.254.133.10
","secEventType":"authentication","messageID":"messageID4","userName":"userName4","Info":"Info4","ta
gs":["_dateparsefailure"],"timeStamp":"Tue 2017 Jan 24, 02:36:31:089","path":"C:/satish/SecurityEven
t-2017-Jan-24.log","@timestamp":"2017-01-24T02:54:50.506Z","info1":"abc4","@version":"1","host":"L24
660WIN","ID":"59ad02fb-4f62-411b-ad59-d825ba045a32","info2":"xyz4"}{"ipaddress":"169.254.133.10","se
cEventType":"dataaccess","messageID":"messageID5","userName":"userName5","Info":"Info5","tags":["_da
teparsefailure"],"timeStamp":"Tue 2017 Jan 24, 02:36:31:090","path":"C:/satish/SecurityEvent-2017-Ja
n-24.log","@timestamp":"2017-01-24T02:54:50.509Z","info1":"abc5","@version":"1","host":"L24660WIN","
ID":"e91e31d1-a31f-458c-8b7e-761161f340c1","info2":"xyz5"}{"ipaddress":"169.254.133.10","secEventTyp
e":"authentication","messageID":"messageID6","userName":"userName6","Info":"Info6","tags":["_datepar
sefailure"],"timeStamp":"Tue 2017 Jan 24, 02:36:31:090","path":"C:/satish/SecurityEvent-2017-Jan-24.
log","@timestamp":"2017-01-24T02:54:50.510Z","info1":"abc6","@version":"1","host":"L24660WIN","ID":"
b7d8fc2c-aed0-40a2-87b8-53d5e45a901e","info2":"xyz6"}08:24:50.624 [Api Webserver] INFO logstash.agent - Successfully start
ed Logstash API endpoint {:port=>9600}
Okay. Then try posting your template file to ES yourself using curl or whatever REST client you prefer to use. Then you'll get any error messages straight from ES.
hi magnus,
it resolved finally.
on doing post it gave errors on certain mappings and types, after resolving them it started working
following is the working template.
"settings" : {
"index" : {
"mappings": {
"default": {
"match" : "
"properties" : {
"@fields": { "type": "object", "dynamic": true },
"ipAddress" : {"type" : "ip", "index" : "analyzed"}
thanks for the suggestions
I'm not by any means good at this, yet....
But this sticks out
Shouldn't that be formatted as the others with "@"?
For consistency perhaps, but otherwise no. It's actually quite unusual that @satishsnv has chosen to prefix the fields like that.
All the other fields are part of the default template, i have added this ipAddress which is part of log. if i keep @ipAddress, i will get a new field of ip type, but my ipAddress field will remain as string. In order to avoid the creation of new field, i didn't used "@". Does this have any impact?
For Logstash 0.x and maybe early 1.x releases perhaps. The only @ fields in reasonably recent releases are @timestamp and @version.
The name itself doesn't matter, but how the field you're using for IP addresses is mapped obviously matters.
