I'm working on logstash-filter-cipher to encode and decode the data. But nothing is coming up.
I have an "ID" field and I want to encode it. The code that I was using is as follows.
host => [ "localhost" ]
index => "test
cipher {
algorithm => "aes-256-cbc"
cipher_padding => 1
iv => "1234567890123456"
key => "12345678901234567890123456789012"
key_size => 32
mode => "encrypt"
source => "ID"
target => "ID_crypted"
base64 => true
cipher {
cipher_padding => 1
key_size => 32
mode => "decrypt"
source => "ID_crypted"
target => "ID_decrypted"
base64 => true
elasticsearch_http
host => "localhost"
index => "new_test"
index_type => "new_test"
stdout {
codec => json
#codec => rubydebug
Please look in to the code and please suggest me if any modifications required
Regards,
Sanjay Reddy
