Hello
I have successfully configured a multi-pipeline. Each pipeline normally loads the data.
My multi-pipeline consists of three jdbc pipeline and one filebeat entry.
This morning I was facing a problem loading data via filebeat to logstash.
Filebeat copied the files to his directory and executed the transfer to logstash.
But I do not know why, logstash did not ingest this data.
I'm have this questions
- Is it possible for one pipeline to impact data load another during its execution?
- How can I be reassured that logstash will process all connector inputs?
Thank you for your suggestions
What does your configuration look like?
Hello Christian
Sorry for the late response, I was missing these days.
My pipeline.yml file is as follows:
pipeline.id: pipeline_1
path.config: "/etc/logstash/conf.d/pipeline_1.conf"
pipeline.id: pipeline_2
path.config: "/etc/logstash/conf.d/pipeline_2.conf"
pipeline.id: pipeline_3
path.config: "/etc/logstash/conf.d/pipeline_3.conf"
I share with you, pipeline_1 which have problem.
beats {
port => 5044
type => "logs"
jdbc {
jdbc_driver_library => "/data/driverSQL/sqljdbc42.jar"
jdbc_driver_class => "com.microsoft.sqlserver.jdbc.SQLServerDriver"
jdbc_connection_string =>
"jdbc:sqlserver://16.10.25.36:236;instanceName=jhhdhjjdj;databasename=database"
jdbc_user => "User_here"
jdbc_password => "Password_here"
#every first sunday of the month, at 22:00
schedule => "0 18 * * sun#1"
statement => "SELECT * FROM [database].[dbo].[table] where date > :sql_last_value"
use_column_value => true
tracking_column => "date"
tracking_column_type => "timestamp"
clean_run => false
last_run_metadata_path => "/etc/logstash/.logstash_jdbc_last_run"
type => "database"
if [type] == "logs" {
hosts => ["localhost:9200"]
user => "user_login"
password => "password"
index => "indexfile"
document_type => "My_document_type"
document_id => "%{[fields_id]}"
}else {
index => "indexdatabase"
This pipeline includes the input beat and one jdbc input. I have the impression that this is my problem.
I plan to separate these two entries into different pipelines, because when I comment the jdbc entry, the beat entry works fine.
I have a question about the pipeline.yml file
Is there a problem using only the main pipeline to start all the connectors and beat input?
pipeline.id: main
path.config: ''/etc/logstash/conf.d/*.conf''
If you are only going to use a main pipeline, there is no need to use pipelines.yml as this is the default behaviour. I would however recommend splitting it up into 4 pipelines as they seem to have different combinations of inputs and outputs.
Ok, thank you.
I come back to you, to confirm is ok.
Hello Christian
All work properly with the 4 separate inputs.
Thank you
