Hi all,
This is my first time using Elasticsearch stack, I initially set up Filebeat, Elasticsearch, and Kibana to ingest the original free OSSEC alert.json file. However, the information was showing up in the message field (under data view Filebeat-*, the only data view I have) rather than with it's own indexed fields which made it hard to search and display.
From what I read, I needed Logstash to apply a template, so I sourced and modified a template to use and edited the output of Filebeat to point at Logstash and the output of Logstash to point at Elasticsearch.
# Option 1: Output to Elasticsearch
hosts => ["https://localhost:9200"] # Adjust to your Elasticsearch host
# index => "ossec-alerts-%{+YYYY.MM.dd}"
user => "logstash_writer"
password => "logstash_writer"
ssl_enabled => true
#ssl_verification_mode => none
ssl_certificate_authorities => ['/etc/logstash/certs/http_ca.crt']
# truststore => "/path/to/truststore.jks"
# truststore_password => "password"
data_stream => true
data_stream_type => "logs"
data_stream_dataset => "ossec-alerts-logs"
# ecs_compatibility => v8
# ecs_compatibility => v1
I also added a user in Elasticsearch called 'logstash_writer' and gave 'all' to cluster privileges, and as the only indices that showed up where the previous 'Filebeat-*', I gave that 'all' also.
Then I started Logstash and got the following:
"fields"=>{"type"=>"ossec_alert"}, "timestamp"=>"2025 Jul 29 01:15:20", "data_stream"=>{"type"=>"logs", "dataset"=>"ossec-alerts-logs", "namespace"=>"default"}}], :error=>{"type"=>"security_exception", "reason"=>"action [indices:data/write/bulk[s]] is unauthorized for user [logstash_writer] with effective roles [logstash_writer] on indices [logs-ossec-alerts-logs-default], this action is granted by the index privileges [create_doc,create,delete,index,write,all]"}}
it's long so I have pasted it below also:
I'm unsure how to continue as I don't have this indices to add privileges against.
I tried:
PUT _data_stream/logs-ossec-alerts-logs-default
in the dev console and then trying to add privileges to it but it doesn't show up as an index (also adding it as a dataview).
After a few days of trying things in desperation I'm a little confused how I progress, any help would be appreciate and I'll also provide what ever configuration data and log data that is needed - I think I have given enough to get this started, but I don't want to overload the initial top post.
Thankyou!
