Yes. That what I had in mind.
I think that your mapping is incorrect.
You should define location as an object with a field coord: Elasticsearch Platform — Find real-time answers at scale | Elastic
My 2 cents
David
Twitter : @dadoonet / @elasticsearchfr / @scrutmydocs
Le 16 oct. 2012 à 03:03, Martin Jambon mjambon@gmail.com a écrit :
On 10/15/2012 05:23 PM, David Pilato wrote:
Hi Martin,
I did not run your test case but I'm wondering if after the doc
insertion, you see something like "update mappings" in logs?
I see that:
[2012-10-15 17:43:36,704][INFO ][cluster.metadata ] [Wendigo] [test1350348216] creating index, cause [api], shards [5]/[1], mappings [doc]
[2012-10-15 17:43:37,825][INFO ][cluster.metadata ] [Wendigo] [test1350348216] update_mapping [doc] (dynamic)
When you get the mapping back, what can you see?
A freshly created index gives me this:
$ curl -XGET "http://127.0.0.1:9200/test1350348216/doc/_mapping?pretty=true"
"doc" : {
"properties" : {
"id" : {
"type" : "string",
"index" : "not_analyzed"
"location.coord" : {
"type" : "geo_point",
"lat_lon" : true
"location2" : {
"lat_lon" : true
But after posting the first document, I get this:
$ curl -XGET 'http://127.0.0.1:9200/test1350348216/doc/_mapping?pretty=true'
"doc" : {
"properties" : {
"id" : {
"type" : "string",
"location" : {
"dynamic" : "true",
"properties" : {
"coord" : {
"dynamic" : "true",
"properties" : {
"lat" : {
"type" : "long",
"ignore_malformed" : false
"lon" : {
"type" : "long",
"lat_lon" : true
"location2" : {
"lat_lon" : true
It looks as if the lack of declaration of the "location" field resulted in an interpretation that ignores the declaration of "location.coord" as soon as a document is posted.
Martin
David
Le 16 oct. 2012 à 01:33, Martin Jambon <mjambon@gmail.com
mailto:mjambon@gmail.com> a écrit :
We are trying to index geographic coordinates present in a subfield, and
can't make it work.
Here is the code to reproduce:
elasticsearch not indexing/finding geo_point in a subfield · GitHub
The last http request is the search query (on location.coord) that
returns 0 result.
The query before that is on the field location2, which returns one
result as expected.
Could be related to this issue:
Redirecting to Google Groups
Any help would be great!
Thanks!
Martin
