Hello , i have two virtuel machines in vmware ESXI , I installed Elasticsearch in the first machine and kibana without Elasticsearch in the second machine and i try to cennect them
this is my Elasticsearch.yml and kibana.yml and tell me it's right configuration or no
cluster.name: my-application
# ------------------------------------ Node ------------------------------------
# Use a descriptive name for the node:
#node.name: node-1
# Add custom attributes to the node:
#node.attr.rack: r1
# ----------------------------------- Paths ------------------------------------
# Path to directory where to store the data (separate multiple locations by com>
path.data: /var/lib/elasticsearch
# Path to log files:
# ----------------------------------- Memory -----------------------------------
# Lock the memory on startup:
#bootstrap.memory_lock: true
# Make sure that the heap size is set to about half the memory available
# on the system and that the owner of the process is allowed to use this
# limit.
# Elasticsearch performs poorly when the system is swapping the memory.
# ---------------------------------- Network -----------------------------------
# By default Elasticsearch is only accessible on localhost. Set a different
# address here to expose this node on the network:
network.host: 0.0.0.0
# By default Elasticsearch listens for HTTP traffic on the first free port it
# finds starting at 9200. Set a specific HTTP port here:
#http.port: 9200
# For more information, consult the network module documentation.
# --------------------------------- Discovery ----------------------------------
# Pass an initial list of hosts to perform discovery when this node is started:
# The default list of hosts is ["127.0.0.1", "[::1]"]
#discovery.seed_hosts: ["host1", "host2"]
# Bootstrap the cluster using an initial set of master-eligible nodes:
#cluster.initial_master_nodes: ["node-1", "node-2"]
# For more information, consult the discovery and cluster formation module docu>
# ---------------------------------- Various -----------------------------------
# Allow wildcard deletion of indices:
#action.destructive_requires_name: false
#----------------------- BEGIN SECURITY AUTO CONFIGURATION -------------------->
# The following settings, TLS certificates, and keys have been automatically >
# generated to configure Elasticsearch security features on 21-04-2022 08:32:36
# Enable security features
xpack.security.enabled: false
xpack.security.enrollment.enabled: true
# Enable encryption for HTTP API client connections, such as Kibana, Logstash, >
xpack.security.http.ssl:
enabled: true
keystore.path: certs/http.p12
# Enable encryption and mutual authentication between cluster nodes
xpack.security.transport.ssl:
enabled: true
verification_mode: certificate
keystore.path: certs/transport.p12
truststore.path: certs/transport.p12
# Create a new cluster with the current node only
# Additional nodes can still join the cluster later
cluster.initial_master_nodes: ["elastic"]
# Allow HTTP API connections from localhost and local networks
# Connections are encrypted and require user authentication
http.host: [_local_, _site_]
#server.port: 5601
# Specifies the address to which the Kibana server will bind. IP addresses and >
# The default is 'localhost', which usually means remote machines will not be a>
# To allow connections from remote users, set this parameter to a non-loopback >
#server.host: "0.0.0.0"
# Enables you to specify a path to mount Kibana at if you are running behind a >
# Use the `server.rewriteBasePath` setting to tell Kibana if it should remove t>
# from requests it receives, and to prevent a deprecation warning at startup.
# This setting cannot end in a slash.
#server.basePath: ""
# Specifies whether Kibana should rewrite requests that are prefixed with
# `server.basePath` or require that they are rewritten by your reverse proxy.
# Defaults to `false`.
#server.rewriteBasePath: false
# Specifies the public URL at which Kibana is available for end users. If
# `server.basePath` is configured this URL should end with the same basePath.
#server.publicBaseUrl: "http://172.19.14.62:5601"
# The maximum payload size in bytes for incoming server requests.
#server.maxPayload: 1048576
# The Kibana server's name. This is used for display purposes.
#server.name: "your-hostname"
# =================== System: Kibana Server (Optional) ===================
# Enables SSL and paths to the PEM-format SSL certificate and SSL key files, re>
# These settings enable SSL for outgoing requests from the Kibana server to the>
#server.ssl.enabled: true
#server.ssl.certificate: /path/to/your/server.crt
#server.ssl.key: /path/to/your/server.key
# =================== System: Elasticsearch ===================
kibana# The URLs of the Elasticsearch instances to use for all your queries.
#elasticsearch.hosts: ["http://localhost:9200"]
# If your Elasticsearch is protected with basic authentication, these settings >
# the username and password that the Kibana server uses to perform maintenance >
# index at startup. Your Kibana users still need to authenticate with Elasticse>
# is proxied through the Kibana server.
#elasticsearch.username: "kibana"
#elasticsearch.password: "Wtlraf7zZl_EGNkrr32Z"
# Kibana can also authenticate to Elasticsearch via "service account tokens".
# Service account tokens are Bearer style tokens that replace the traditional u>
# Use this token instead of a username/password.
# elasticsearch.serviceAccountToken: "my_token"
# Time in milliseconds to wait for Elasticsearch to respond to pings. Defaults >
# the elasticsearch.requestTimeout setting.
#elasticsearch.pingTimeout: 1500
# Time in milliseconds to wait for responses from the back end or Elasticsearch>
# must be a positive integer.
#elasticsearch.requestTimeout: 30000
# Specifies whether Kibana should use compression for communications with elast>
#elasticsearch.compression: false
# List of Kibana client-side headers to send to Elasticsearch. To send *no* cli>
# headers, set this value to [] (an empty list).
#elasticsearch.requestHeadersWhitelist: [ authorization ]
# Header names and values that are sent to Elasticsearch. Any custom headers ca>
# by client-side headers, regardless of the elasticsearch.requestHeadersWhiteli>
#elasticsearch.customHeaders: {}
# Time in milliseconds for Elasticsearch to wait for responses from shards. Set>
#elasticsearch.shardTimeout: 30000
# =================== System: Elasticsearch (Optional) ===================
# These files are used to verify the identity of Kibana to Elasticsearch and ar>
#elasticsearch.ssl.key: /path/to/your/client.key
# Enables you to specify a path to the PEM file for the certificate
# authority for your Elasticsearch instance.
#elasticsearch.ssl.certificateAuthorities: [ "/path/to/your/CA.pem" ]
# To disregard the validity of SSL certificates, change this setting's value to>
#elasticsearch.ssl.verificationMode: full
# =================== System: Logging ===================
# Set the value of this setting to off to suppress all logging output, or to de>
#logging.root.level: debug
# Enables you to specify a file where Kibana stores log output.
#logging:
# appenders:
# file:
# type: file
# fileName: /var/log/kibana/kibana.log
# layout:
#logging.loggers:
# - name: elasticsearch.query
# level: debug
# Logs http responses.
#logging.loggers:
# - name: http.server.response
# level: debug
# Logs system usage information.
#logging.loggers:
# - name: metrics.ops
# level: debug
# =================== System: Other ===================
# The path where Kibana stores persistent data not saved in Elasticsearch. Defa>
#path.data: data
# Specifies the path where Kibana creates the process ID file.
#pid.file: /run/kibana/kibana.pid
# Specifies locale to be used for all localizable strings, dates and number for>
# Supported languages are the following: English - en , by default , Chinese - >
#i18n.locale: "en"
# =================== Frequently used (Optional)===================
# =================== Saved Objects: Migrations ===================
# Saved object migrations run at startup. If you run into migration-related iss>
# The number of documents migrated at a time.
# If Kibana can't start up or upgrade due to an Elasticsearch `circuit_breaking>
# use a smaller batchSize value to reduce the memory pressure. Defaults to 1000>
#migrations.batchSize: 1000
# The maximum payload size for indexing batches of upgraded saved objects.
# To avoid migrations failing due to a 413 Request Entity Too Large response fr>
# This value should be lower than or equal to your Elasticsearch cluster’s `htt>
# configuration option. Default: 100mb
#migrations.maxBatchSizeBytes: 100mb
# The number of times to retry temporary migration failures. Increase the setti>
# if migrations fail frequently with a message such as `Unable to complete the >
# 15 attempts, terminating`. Defaults to 15
#migrations.retryAttempts: 15
# =================== Search Autocomplete ===================
# Time in milliseconds to wait for autocomplete suggestions from Elasticsearch.
# This value must be a whole number greater than zero. Defaults to 1000ms
#data.autocomplete.valueSuggestions.timeout: 1000
# Maximum number of documents loaded by each shard to generate autocomplete sug>
# This value must be a whole number greater than zero. Defaults to 100_000
#data.autocomplete.valueSuggestions.terminateAfter: 100000
### >>>>>>> BACKUP END: Kibana interactive setup (2022-04-28T11:03:35.457Z)
