Hello guys,
I'm having problem trying to get my ruby code filter into an external ruby file called test2.rb
When i was using a ruby {} inside my configuration, it was working very well, and i am new to ruby so maybe my mistakes are basics and i am sorry for this.
In my logstash.conf i'm calling ruby this way :
ruby {
path => "C:\Users\T6SH\Desktop\Logstash\Ruby\test2.rb"
Then my test2.rb looks like :
def filter(event)
if event.get("[event][dataset]") == "system.process"
if event.get("[process][name]").downcase == "svchost.exe"
event.set("process.w3wp_application_pool", event.get("[process][args]")[event.get("[process][args]").index("-k")+1])
event.set("process.app_name", "svchost - " + event.get("[process][args]")[event.get("[process][args]").index("-k")+1])
return [event]
elsif event.get("[process][name]").downcase == "java.exe"
if event.get("[process][args]").include?("-jar")
event.set("process.java_app_name", event.get("[process][args]")[event.get("[process][args]").index("-jar")+1])
event.set("process.app_name", "java - " + event.get("[process][args]")[event.get("[process][args]").index("-jar")+1])
return [event]
elsif event.get("[process][args]").include?("-cp")
event.set("process.java_app_name", event.get("[process][args]")[event.get("[process][args]").index("-cp")+2])
event.set("process.app_name", "java - " + event.get("[process][args]")[event.get("[process][args]").index("-cp")+2])
return [event]
end
else
return event.set("process.app_name", event.get("[process][name]"))
end
elsif event.get("[event][dataset]") == "windows.service"
if event.get("[windows][service][name]").downcase.start_with?("fgs","elasticsearch","w3svc","metricbeat","sos_scheduler_","msmq","msdtc")
return [event.set("windows.service.is_critical", true) ]
else
return [event.set("windows.service.is_critical", false) ]
end
end
end
My error :
Could not process event: Custom script did not return an array from 'filter'. Only arrays may be returned!
backtrace=>["C:/Users/T6SH/Desktop/Logstash/vendor/bundle/jruby/2.5.0/gems/logstash-filter-ruby-3.1.5/lib/logstash/filters/ruby.rb:69:in `check_result_events!'", "C:/Users/T6SH/Desktop/Logstash/vendor/bundle/jruby/2.5.0/gems/logstash-filter-ruby-3.1.5/lib/logstash/filters/ruby.rb:101:in `file_script'",
"C:/Users/T6SH/Desktop/Logstash/vendor/bundle/jruby/2.5.0/gems/logstash-filter-ruby-3.1.5/lib/logstash/filters/ruby.rb:84:in `filter'", "C:/Users/T6SH/Desktop/Logstash/logstash-core/lib/logstash/filters/base.rb:143:in `do_filter'",
"C:/Users/T6SH/Desktop/Logstash/logstash-core/lib/logstash/filters/base.rb:162:in `block in multi_filter'", "org/jruby/RubyArray.java:1800:in `each'",
"C:/Users/T6SH/Desktop/Logstash/logstash-core/lib/logstash/filters/base.rb:159:in `multi_filter'", "org/logstash/config/ir/compiler/AbstractFilterDelegatorExt.java:115:in `multi_filter'",
"C:/Users/T6SH/Desktop/Logstash/logstash-core/lib/logstash/java_pipeline.rb:243:in `block in start_workers'"]}
Before this i had a return for every event.set, but i didnt return array so i tried to had them in array then i tried to return like above an [event] array but i m losing my mind ...I feel like im coding blindly...
I hope i was clear enough, thanks for your future help and have a nice day !
Sincerly trying, Luigi
