Problem Using Filebeat for logging ssh log in
SSh logs are not being shown in the kibana, I am pushing my logs to the ES Only
I am using the following configuration,
OS - Ubuntu 20.04
ES - 7.11.0
LogStash - 7.11.0
Kibana - 7.11.0
FileBeat - 7.11.0
The enabled module in filebeat is System
System.yml file :
- module: system
  # Syslog
  syslog:
    enabled: true
    # Set custom paths for the log files. If left empty,
    # Filebeat will choose the paths depending on your OS.
    #var.paths:
    var.paths: ["/var/log/messages"]
  # Authorization logs
    var.convert_timezone: true
  auth:
    enabled: true
    #var.paths:
    var.paths: ["/var/log/secure"]
With the console in kibana i have
POST /filebeat-*/_search
"size": 10,
"match": {
"source": "/var/log/messages"
Output :
  "took" : 0,
  "timed_out" : false,
  "_shards" : {
    "total" : 1,
    "successful" : 1,
    "skipped" : 0,
    "failed" : 0
  "hits" : {
    "total" : {
      "value" : 0,
      "relation" : "eq"
    "max_score" : null,
    "hits" : [x]
For
GET _nodes/stats/ingest
I have :
  "_nodes" : {
    "total" : 1,
    "successful" : 1,
    "failed" : 0
  "cluster_name" : "my-application",
  "nodes" : {
    "L_HA_nnGQ9OfQiW-4y4q0w" : {
      "timestamp" : 1613472269331,
      "name" : "node-1",
      "transport_address" : "192.168.1.26:9300",
      "host" : "192.168.1.26",
      "ip" : "192.168.1.26:9300",
      "roles" : [
        "data",
        "data_cold",
        "data_content",
        "data_hot",
        "data_warm",
        "ingest",
        "master",
        "ml",
        "remote_cluster_client",
        "transform"
      "attributes" : {
        "ml.machine_memory" : "3093676032",
        "xpack.installed" : "true",
        "transform.node" : "true",
        "ml.max_open_jobs" : "20",
        "ml.max_jvm_size" : "1547698176"
      "ingest" : {
        "total" : {
          "count" : 0,
          "time_in_millis" : 0,
          "current" : 0,
          "failed" : 0
        "pipelines" : {
          "filebeat-7.11.0-system-syslog-pipeline" : {
            "count" : 0,
            "current" : 0,
            "failed" : 0,
            "processors" : [
                "set" : {
                  "type" : "set",
                  "stats" : {
                    "count" : 0,
                    "current" : 0,
                    "failed" : 0
"filebeat-7.11.0-system-auth-pipeline" : {
            "count" : 0,
            "current" : 0,
            "failed" : 0,
            "processors" : [
                "set" : {
                  "type" : "set",
                  "stats" : {
                    "count" : 0,
                    "current" : 0,
                    "failed" : 0
Please, can you parse your post in markdown? What's the output of filebeat?
What do you mean by "output of filebeat" ? You want to see my filebeat.yml ?
I just solve my problem ... because in my system.yml
- module: system
  # Syslog
  syslog:
    enabled: true
    #var.paths:
  auth:
    enabled: true
    #var.paths:
My 2 paths were wrong, they doesn't exists in Ubuntu ... So i replace
by :
var.paths: ["/var/log/syslog"]
and
by
var.paths: ["/var/log/auth.log"]
What a mistake :slight_smile:
