Problem Watchers Failed Logins Index out of bounds exception Index 0 out of bounds for length 0
Hi Experts,
Currently I have an error that I have not been able to solve in a watcher, I am making some failed logins, so that when more than 3 attempts are detected per user it is activated and sends a notification by mail. However I have an error that appears when executing the watcher. This is my code and my mistake. I tried using a size: 50 or higher values but I don't really know how it works, previously it was in size: 0
  "trigger": {
"schedule": {
  "interval": "15m"
  "input": {
"search": {
  "request": {
    "indices": [
      "o365beat-*"
    "rest_total_hits_as_int": true,
    "body": {
      "size": 50,
        "bool": {
          "must": [],
          "filter": [
              "bool": {
                "filter": [
                    "bool": {
                      "should": [
                          "match_phrase": {
                            "Workload": "AzureActiveDirectory"
                      "minimum_should_match": 1
                    "bool": {
                      "should": [
                          "match_phrase": {
                            "event.action": "UserLoginFailed"
              "range": {
                "@timestamp": {
                  "gte": "now-15m",
                  "lte": "now"
          "should": [],
          "must_not": []
      "aggs": {
        "by": {
          "terms": {
            "field": "user.id.keyword"
  "condition": {
"compare": {
  "ctx.payload.aggregations.by.buckets.0.doc_count": {
    "gt": 3
  "actions": {
"send_email": {
  "email": {
    "profile": "gmail",
    "attachments": {
      "loginfailde.csv": {
        "reporting": {
          "url": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
          "retries": 80,
          "interval": "4s",
          "auth": {
            "basic": {
              "username": "XXXXXXXXXXXXXX",
              "password": "XXXXXXXXXXXXXX"
    "to": [
      "parami@paramiotravez"
    "subject": "New Event",
    "body": {
      "text": "Se han detectado {{ctx.payload.aggregations.by.buckets.0.doc_count}} evento(s) relacionado(s) con Intentos de Inicio de Sesión Fallidos"
And the error is the following
"actions": []
"exception": {
"type": "index_out_of_bounds_exception",
"reason": "Index 0 out of bounds for length 0"
if ctx.payload.aggregations.by.buckets is an empty array because no documents are matching your query, you will face this exception.
You might want to use a script condition like
"condition" : {
  "script" : {
    "source" : "return ctx.payload.aggregations.buckets.size() > 0 && ctx.payload.aggregations.by.buckets.0.doc_count > 3"
instead of the second part of the condition you could also go with min_doc_count
