Problem when creating an index not analyzed, to perform term searches in texts
Try to create an index with a field that is not analyzed in order to perform a string search. But when I try to create the index it generates errors.
In this way I create the index:
PUT / contents
"mappings": {
"category": {
"_all": {"enabled": false},
"_source": {"compressed": true},
"properties": {
"name": {"type": "text", "index": "analyzed"}
and it generates me error:
"error": {
"root_cause": [
"type": "mapper_parsing_exception",
"reason": "Failed to parse mapping [category]: Could not convert [name.index] to boolean"
"reason": "Failed to parse mapping [category]: Could not convert [name.index] to boolean",
"caused_by": {
"reason": "Could not convert [name.index] to boolean",
"caused_by": {
"reason": "Failed to parse value [analyzed] as only [true] or [false] are allowed."
"status": 400
How it should create that certain fields are not analyzed so you can search the text strings.
Hi, since Elasticsearch version 5.x, you can use the keyword datatype for not analysed strings (https://www.elastic.co/guide/en/elasticsearch/reference/current/keyword.html).
