This does not seem to work, because ES is treating the period as JSON
dot-notation. We've tried to escape the period to no avail. So the
documents we post look like:
{"A.field": "4000/1"}
But ES expects it to look like:
{"A": {"field": "4000/1"}}
So we end up having an auto-generated "_id" anyways.
A couple of questions:
Are there other "gotchas" like this caused by having periods in fields?
Is that just generally a bad idea?
Is it recommended to not overwrite the "_id" field? Our IDs for our
documents look like that above; are string IDs a bad idea? Is the slash a
problem? Does it affect hashing/distribution of documents?
fields? Is that just generally a bad idea?
It is generally a bad idea.
slash a problem? Does it affect hashing/distribution of documents?
It is fine to override the _id field. The slash may be tricky, because
it needs to be passed in the URL, so you should make sure that it is
always URI escaped: 4000%2F1
I figured it would be a bad idea to have periods in fields (due to Object
type and JSON dot notation for referencing nested fields), but the system
we are migrating from has a period in just about every field. I am assuming
there is no such thing as "field aliasing" in ES? Could not confirm or
deny this based on the brief research I did.
And thanks for the heads up with the slashes in the _id field. Figured it
had to be URI escaped.
Ash
On Tuesday, January 22, 2013 9:48:27 AM UTC-5, Clinton Gormley wrote:
Hiya Ash
Object type and JSON dot notation for referencing nested fields), but
the system we are migrating from has a period in just about every
field. I am assuming there is no such thing as "field aliasing" in ES?
Could not confirm or deny this based on the brief research I did.
You could try using the 'index_name' parameter in the field mapping to
control in field names in the index, but that introduces a level of
complexity that would be best avoided.
You say that you're migrating from an old system - it'd surely be better
in the long run to go ahead and rename your fields
