We are testing and want to move to ES 5 from ES 1.5.2, the log source PUT into ES looks like this:
{code}
"_index": "esb-2016.08.15",
"_type": "ESB",
"_id": "AVaM_VjDQw5s6KmmdycR",
"_score": null,
"_source": {
"eventUUID": "7f95b9a3-439e-4c11-ba10-a5649ec0a83d",
"category": "osgi",
"eventType": "OSGiEvent",
"logMessage": "org.osgi.framework.BundleEvent[source=locator-monitor_6.3.0.SNAPSHOT [310]]",
"logSource": {
"host.name": "xldai-PC",
"process.id": "8244",
"topic": "org/osgi/framework/BundleEvent/STARTED"
"logTimestamp": "2016-08-15T06:57:07.330+0000",
"agentId": "agentXilai",
"agentTimestamp": "2016-08-15T06:57:07.330+0000",
"serverTimestamp": "2016-08-15T06:57:08.776+0000",
"audit": false,
"customInfo": {
"bundle": "locator-monitor_6.3.0.SNAPSHOT [310]",
"bundle.id": "310",
"bundle.symbolicName": "locator-monitor",
"timestamp": "1471244227330"
{code}
It worked well when PUT this log into ES 1.5.2, but failed on ES 5 with this exception:
{code}
[2016-08-15 15:50:35,680][DEBUG][rest.suppressed ] path: /talendesb-2016.08.16/ESB/123456, params: {pretty=true
, index=esb-2016.08.15, id=123456, type=ESB}
RemoteTransportException[[node-xld][127.0.0.1:9300][indices:data/write/index[p]]]; nested: IllegalArgumentException[Can'
t merge a non object mapping [customInfo.bundle] with an object mapping [customInfo.bundle]];
Caused by: java.lang.IllegalArgumentException: Can't merge a non object mapping [customInfo.bundle] with an object mappi
at org.elasticsearch.index.mapper.object.ObjectMapper.merge(ObjectMapper.java:459)
{code}
If rename the "bundle" field into something else e.g. "bundleObj", then it can be PUT into ES 5 successfully.
{code}
"customInfo": {
"bundleObj": "locator-monitor_6.3.0.SNAPSHOT [310]",
"bundle.id": "310",
{code}
Any suggestions for this problem? (rename field name is not good because will incompatible with the existing our product)
But seems the field names with dot (e.g. bundle.id) works well, the problem is happen only when the "bundle" and "bundle.id" co-existing in a same json element.
and got this exception in the ES 5 logs:
[2016-08-17 15:47:35,266][DEBUG][rest.suppressed ] path: /talendesb-2016.08.17/ESB, params: {index=talendesb-20
16.08.17, type=ESB}
RemoteTransportException[[_-Moa3H][127.0.0.1:9300][indices:data/write/index[p]]]; nested: IllegalArgumentException[Can't
at org.elasticsearch.index.mapper.object.ObjectMapper.merge(ObjectMapper.java:57)
at org.elasticsearch.index.mapper.DocumentParser.createDynamicUpdate(DocumentParser.java:211)
at org.elasticsearch.index.mapper.DocumentParser.parseDocument(DocumentParser.java:91)
at org.elasticsearch.index.mapper.DocumentMapper.parse(DocumentMapper.java:286)
at org.elasticsearch.index.shard.IndexShard.prepareIndex(IndexShard.java:511)
{"error":{"root_cause":[{"type":"remote_transport_exception","reason":"[_-Moa3H][127.0.0.1:9300][indices:data/write/inde
x[p]]"}],"type":"illegal_argument_exception","reason":"Can't merge a non object mapping [customInfo.bundle] with an obje
ct mapping [customInfo.bundle]"},"status":400}
I just want to be sure here it's an ES 5 mapping issue or invalid data issue before I open an issue ticket.
So it maps "bundle" as on object. But then "bundle" also needs to be mapped as a string due to
"bundle": "111"
which causes mapping conflicts since bundle is also mapped as an object. You would need to organize you documents differently in order not to have such conflicts.
logo are trademarks of the
Apache Software Foundation
