Problem with Dashboard on system module (URGENT)
I get the following error, I don't understand why this is happening. Why not load values?
Logstash
  beats {
    port => 5044
    hosts => ["http://172.28.26.152:9200"]
	manage_template => false
System.module
- module: system
  period: 10s
  enabled: true
  processes: ['.*']
  metricsets:
    - cpu
    - memory
    - network
    - process
    - process_summary
    - diskio
    - core
  cpu.metrics:  ["percentages"]  # The other available options are normalized_percentages and ticks.
  core.metrics: ["percentages"]  # The other available option is ticks.
  process.include_top_n:
    by_cpu: 5      # include top 5 processes by CPU
    by_memory: 5   # include top 5 processes by memory
- module: system
  period: 1m
  metricsets:
    - filesystem
    - fsstat
- module: system
  period: 10s
  metricsets:
    - uptime
The Logstash hosts
output.logstash:
  hosts: ["172.28.26.152:5044"]
Picture 1
I use bellow system component
Kibana version:
6.6.1
Logstash version:
6.6.1
Elasticsearch version:
6.6.1
Metricbeat version:
6.6.1
OS version:
Windows server 12
Did you load the index template for metricbeat?
How do I do?
is this picture?
I was referring to the elasticsearch index template: https://www.elastic.co/guide/en/elasticsearch/reference/current/indices-templates.html If you send data to Elasticsearch from Metricbeat, it loads it automatically, if you send it through Logstash, you need to load it manually.
I think this problem is very hard. I use approach Beat ---> Logstash --> Elastic --> Kibana so can you share example for metricbeat ?
Hi Ruflin
I solved the problem. As you say load metricbeat field manually. My solution approach;
setup.template.name: "metricbeat"
setup.template.fields: "fields.yml"
setup.template.overwrite: false
Thank you for response
Best Regards
Glad you found the solution and thanks for sharing.
