Problem with date filter
I have been trying to use the date filter plugin but without success. I am trying to parse a field and target it into @timestamp field.
My message field contains a date string like the following:
2022-05-09 09:19:07,900 [xJQsL/r76U:396] DEBUG
I am creating two new fields: modb.date and modb.ms. The field mobd.date and modb.ms are corretly parsed , and respectively get the values 2022-05-09 09:19:07 and 900. Then i concatenate both to create a new field called modb.time with the format 2022-05-09 09:19:07.900.
The problem happens when i try to use the date filter on this modb.time field. When the documents get indexed i can see on the field tags, "_dateparsefailure". I have tried to parse with multiple formats but without success.
I can only parse the modb.time value when i remove the miliseconds (.SSS) in the parsing format.
    dissect {
        mapping => { "message" => "%{[modb][date]},%{[modb][ms]}[" }
    mutate {
        add_field => { "[modb][time]" => "%{[modb][date]}.%{[modb][ms]}" }
    date {
        #match => [ "timestamp", "MM/d/yyyy h:mm:ss a" ]
        match => [ "[modb][time]", "yyyy-MM-dd hh:mm:ss.SSS" ]
        target => ["@timestamp"]
Do you have any ideias why is this happening?
Regards
There is a space after the ms in timestamp and the [ that isn't account for in the Grok pattern.
Try this. %{[modb][date]},%{[modb][ms]} [
Nice finding :sweat_smile: It was resolved with your solution.
Thank you!
Seems like i am having issues again with the date filter. Yesterday was working fine, but today is not working anymore...
Field to be parsed by date filter: 2022-05-10 15:11:28.209
Filter used:
date {
I didn't touch the date filter since it was working.
Do you see anything that i am not seeing?
Regards
Try big H's for the hour. Documentation.
match => [ "[modb][time]", "yyyy-MM-dd HH:mm:ss.SSS" ]
Thanks Aaron, it is working. I was confused since with the previous pattern worked and suddenly stopped.
