Problem with element BY.ID for autologin to kibana using python selenium webdriver
I want to make an auto screenshot script using selenium python but I can't find element id of the username and password that I found is only random element id for username and password. Could you please inform me if I can do auto login to elastic kibana using selenium python? If it's possible, what parameter should I use for the username and password element id?
Thank you.
As there are no Ids there are 2 ways to do that:
  1. Use the name instead of the id: Docs
  2. Instead of using the User Interface to Login you can also send the authentication as part of a Basic Auth Header. As Kibana does not allow user/password in the Url you need to use the browsers DevTools to do that. Here is a Java example to do that with Selenium.
Best regards
Wolfram
Thank you for helping me, i use "Name" for element and it works
