Problem with icu_normalizer and acute accent
Hi!
I'm having an issue with icu_normalizer and acute accents and I don't know if it's something I'm not seeing, a bug, a misconfiguration or what. I'm very new with ES.
I have an analyzer using a char_filter based on icu_normalizer and type nfkc.
Testing the analyzer, the acute accents are merged with the following character. Then I can search the documents with the original text, but not filter them.
I tested it with ES 1.7 in Debian and 5.4.1 in OSX, both with java 1.8.
A document with an attribute using acute accent is created, when I do a search, it is returned:
                "match": {
                        "photo.location.exact": {
                                "query": "Li´ege"
But when I try to filter by the original string, it's not returned:
    "size": 1000,
    "from": 0,
        "filtered": {
                "bool": {
                    "minimum_should_match": 1,
                    "must": [
                            "terms": {
                                "photo.location.exact": [
                                    "NY",
                                    "París",
                                    "Li´ege"
If I change Li´ege with the text returned by analyzing it, the document is returned.
My index:
  "documents": {
    "aliases": {},
    "mappings": {},
    "settings": {
      "index": {
        "number_of_shards": "5",
        "provided_name": "documents",
        "creation_date": "1497468479974",
        "analysis": {
          "filter": {
            "truncate_field": {
              "length": "1000",
              "type": "truncate"
          "analyzer": {
            "exact_analyzer": {
              "filter": [
                "truncate_field"
              "char_filter": "nfkc_normalizer",
              "type": "custom",
              "tokenizer": "keyword"
          "char_filter": {
            "nfkc_normalizer": {
              "name": "nfkc",
              "type": "icu_normalizer"
        "number_of_replicas": "1",
        "uuid": "eeDA54FiQJ2FGq3tSVRfnQ",
        "version": {
          "created": "5040199"
I wrote a Python script which create the index, populate the DB with 3 documents and do the searchs, it can be downloaded from here.
What am I doing wrong?
Thanks!!!
One more thing; using nfc instead of nfck, everything works right. Why?
Any clue?
