Problem with Mapping Templates
I created a field mapping for keyword only field and ingested the data to ES,but I could still see field.keyword in my index.
In my case field name is AB.Field1
Is it due to .(dot) in my field Name or any other issue?
   PUT _template/test1
    "order": 9,
    "version": 1,
    "index_patterns": [
      "test1*",
      "test2*"
    "settings": {
      "index": {
        "number_of_shards": "2",
        "number_of_replicas": "1",
        "refresh_interval": "5s"
    "mappings": {
        "dynamic_templates": [
            "keyword_only_field": {
              "match_pattern": "regex",
              "match": "^(AB.Field1|BC.Field1|AB.Field2|BC.Field2)$",
              "match_mapping_type": "string",
              "mapping": {
                "type": "keyword",
                "ignore_above": 256
    "aliases": {}
Yes, it is due to the dot. You need to expand the field definition in the mapping.
You could define a regular (not dynamic) mapping for {"AB": {"Field1": <keyword only definition>}}. Your regex is currently just a convenient list of field names, but it's not doing any wider matching like using wildcards *.
If you're sure Field1 will always need to be keyword-only across all AB, BC etc. parent objects, you could use a simple "match": "Field1"dynamic template without regex. E.g.:
PUT _template/test1
    "order": 9,
    "version": 1,
    "index_patterns": [
      "test1*",
      "test2*"
    "settings": {
      "index": {
    "mappings": {
              "match": "Field1",
              "mapping": {
                "type": "keyword",
                "ignore_above": 256
    "aliases": {}
I tested that in Kibana Dev Console on Elasticsearch 7.9.1. After saving that dynamic template:
PUT test1index
PUT test1index/_doc/testdoc1
  "AB": {"Field1": "value1"},
  "regular_field": "regular value"
GET test1index/_doc/testdoc1
GET test1index/_mapping
The last query results in
"properties" : {
        "AB" : {
          "properties" : {
            "Field1" : {
              "type" : "keyword",
              "ignore_above" : 256
        "regular_field" : {
          "type" : "text",
          "fields" : {
            "keyword" : {
              "type" : "keyword",
which seems to be what you want.
Great Thanks a lot!
