Problem with metricbeat and xpack
I have the following problem, after installing X-pack, I would like my metricbeat agents that I have collecting data from other servers can send these to the EL cluster that I have mounted.
The installation of X-pack that I have, is linked to an active directory, in principle without problems.
I have several groups mapped in AD and in Xpack and the users that belong to them access the contents that have been authorized by x-pack.
Now, for the metricbebat agents, in AD only we have created a user, not a group and I see no way to give this user access to the cluster without this one not in an AD group.
Is it possible, through X-pack configuration, to authorize a discrete user who does not belong to a specific AD group to perform data in an EL cluster?
regards,
Hi Oscar,
Yes, you can create "native" users or use PKI/certificate-based auth alongside your AD realm.
You can read about the native realm here[1] and our authentication options more generally here[2]
[1] https://www.elastic.co/guide/en/x-pack/current/native-realm.html
[2] https://www.elastic.co/guide/en/x-pack/current/setting-up-authentication.html
Thanks,
Steve
Thx for your answer!
