Hi all,
We are migrating some queries used on logstash on a previous DB2 pipeline to a new oracle database pipeline.
We have checked them on db clients like Dbvisualizer or dbviewer and running these converted queries on those clients they run ok and we get the results we expect to see...
But when we run exactly the same queries through logstash on the pipeline we get this error on 4 of them:
[2025-02-19T13:48:00,365][ERROR][logstash.inputs.jdbc ][pasarelas][74271d402d8c348a7bb2902d60c97784c82a7b2ce1db74c13e541df17bc84b28] Java::JavaSql::SQLDataException: ORA-01830: date format picture ends before converting entire input string: select FEC_REGISTRO,
NOM_WS as SERVICIO,
IDE_USU_EMP,
HOR_INI_REGISTRO,
HOR_FIN_REGISTRO,
TO_DATE(CONCAT(CONCAT(TO_CHAR(CAST(FEC_REGISTRO as date),'YYYY-MM-DD'),' '),TO_CHAR(HOR_INI_REGISTRO,'TS')),'YYYY-MM-DD HH24:MI:SS') as FECHATMST,
NUM_INVOCACIONES,
NUM_EJE_CORREC,
NUM_EJE_ERROR,
NUM_NO_EJE_POOL,
NUM_TMP_TOT_ESP,
NUM_TMP_MED_ESP_P,
NUM_TMP_MAX_ESP_P,
NUM_TMP_MIN_ESP_P,
NUM_EJE_SIN_ESP,
NOM_NODO,
NUM_MAX_ESP_R_IN,
NUM_MED_ESP_R_IN,
NUM_TOT_ESP_R_IN
from DB2H.HCTBF1W where
FEC_REGISTRO >= SYSDATE - interval '1' day and
TO_DATE(CONCAT(CONCAT(TO_CHAR(CAST(FEC_REGISTRO as date),'YYYY-MM-DD'),' '),TO_CHAR(HOR_INI_REGISTRO,'TS')),'YYYY-MM-DD HH24:MI:SS') >= CURRENT_TIMESTAMP - interval '120' minute and
substr(TO_CHAR(HOR_INI_REGISTRO,'TS'),1,2) = substr(TO_CHAR(sysdate - interval '60' minute,'TS'),1,2)
Any idea what we are missing??
best regards
Borja
