Problem with parsing fields starts or ends with dot(.)
From nested json fields some fields starts with dot or ends with dot this causing problem on Elasticsearch "Object field starting or ending with a [.] makes object resolution ambiguous: ]"
What is the best optimal solution for this issue?
