Problem with terms facet multi fields?
Hello
Why does not like Mysql count(DISTINCT userId, prdId) ??
"facets": {
"book": {
"terms": {
"fields": [
"userId","prdId"
"size": 10,
"order": "count"
"size": 0
result :
"facets": {
"book": {
"_type": "terms",
"missing": 299410,
"total": 1765354,
"other": 1483806,
"terms": [
"term": "(Facebook)abc@gmail.com",
"count": 119710
"term": "guest",
"count": 76341
"term": "0100051552",
"count": 18563
Is't my misunderstanding?? or I lost other parameter??
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/529a0f7d-5b1a-4f5a-b76e-6fc7b920dcb6%40googlegroups.com.
The terms facet will use a combo of term values from all the fields as if
it was a single field. What you want to do is probably a script that
combines userId and prodId, and then does a terms facet on the full combo.
Assuming that userId and prodId are full single tokens (i.e. for example
not_analyzed"), you can do something like this:
"facets": {
"user_prod": {
"terms": {
"script": "doc['userId'].value.toString() +
doc['prodId'].value.toString()"
And if you want the total distinct count, you will need to turn on
all_terms and then count the number of terms returned in the facet array.
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/18c32f65-00ed-4adf-bb8f-9d8c157b72a6%40googlegroups.com.
Thanks Binh
But, In elasticsearch, How to count the number of terms returned in the
facet array?
I found the doc. Not include facet array length function.
Do you have any suggest??
Thanks again.
Binh Ly於 2014年3月4日星期二UTC+8上午4時16分42秒寫道:
"facets": {
"user_prod": {
"terms": {
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/d45217b7-e7cc-4153-8608-ab6f7b1ff9d1%40googlegroups.com.
