Problem with Tomcat multiline entries
Hey all -
I'm trying to get filebeats to forward some of my Tomcat logs, but I can't seem to get the multiline stuff quite right. The log file is a mix of single-line entries and multiline. Any help would be appreciated.
Here is my config for multiline:
  multiline.pattern: '^[[:space:]]'
  multiline.pattern: '^[[:space:]]+|^Caused by:'
  multiline.negate: true
  multiline.match: after
Here is an example of the logs I'm trying to get consumed by filebeats:
22-May-2017 11:32:03.854 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=/srv/app/tomcat/tomcat1
22-May-2017 11:32:03.855 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=/usr/share/tomcat8
22-May-2017 11:32:03.855 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.endorsed.dirs=
22-May-2017 11:32:03.855 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
22-May-2017 11:32:03.855 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.pa
th: /usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
22-May-2017 11:32:04.988 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8082"]
22-May-2017 11:32:05.352 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
22-May-2017 11:32:05.431 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-8009"]
22-May-2017 11:32:05.432 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
22-May-2017 11:32:05.470 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 4755 ms
22-May-2017 11:32:12.299 WARNING [main] org.apache.naming.NamingContext.lookup Unexpected exception resolving reference
 java.sql.SQLException: Cannot create PoolableConnectionFactory (IO Error: The Network Adapter could not establish the connection)
        at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:2294)
        at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:2038)
        at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.getLogWriter(BasicDataSource.java:1587)
        at org.apache.tomcat.dbcp.dbcp2.BasicDataSourceFactory.createDataSource(BasicDataSourceFactory.java:594)
        at org.apache.tomcat.dbcp.dbcp2.BasicDataSourceFactory.getObjectInstance(BasicDataSourceFactory.java:274)
        at org.apache.naming.factory.FactoryBase.getObjectInstance(FactoryBase.java:94)
        at javax.naming.spi.NamingManager.getObjectInstance(NamingManager.java:321)
        at org.apache.naming.NamingContext.lookup(NamingContext.java:841)
        at org.apache.naming.NamingContext.lookup(NamingContext.java:152)
        at org.apache.naming.NamingContext.lookup(NamingContext.java:829)
        at org.apache.naming.NamingContext.lookup(NamingContext.java:166)
        at org.apache.catalina.core.NamingContextListener.addResource(NamingContextListener.java:1091)
        at org.apache.catalina.core.NamingContextListener.createNamingContext(NamingContextListener.java:670)
        at org.apache.catalina.core.NamingContextListener.lifecycleEvent(NamingContextListener.java:258)
        at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:95)
        at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:90)
        at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:781)
        at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:147)
        at org.apache.catalina.startup.Catalina.start(Catalina.java:629)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:498)
        at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:351)
        at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:485)
Caused by: java.sql.SQLRecoverableException: IO Error: The Network Adapter could not establish the connection
        at oracle.jdbc.driver.T4CConnection.logon(T4CConnection.java:743)
        at oracle.jdbc.driver.PhysicalConnection.connect(PhysicalConnection.java:666)
        at oracle.jdbc.driver.T4CDriverExtension.getConnection(T4CDriverExtension.java:32)
        at oracle.jdbc.driver.OracleDriver.connect(OracleDriver.java:566)
        at org.apache.tomcat.dbcp.dbcp2.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
        at org.apache.tomcat.dbcp.dbcp2.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:255)
        at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.validateConnectionFactory(BasicDataSource.java:2304)
        at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:2290)
        ... 24 more
Caused by: oracle.net.ns.NetException: The Network Adapter could not establish the connection
        at oracle.net.nt.ConnStrategy.execute(ConnStrategy.java:470)
        at oracle.net.resolver.AddrResolution.resolveAndExecute(AddrResolution.java:506)
        at oracle.net.ns.NSProtocol.establishConnection(NSProtocol.java:595)
        at oracle.net.ns.NSProtocol.connect(NSProtocol.java:230)
        at oracle.jdbc.driver.T4CConnection.connect(T4CConnection.java:1452)
        at oracle.jdbc.driver.T4CConnection.logon(T4CConnection.java:496)
        ... 31 more
Caused by: java.net.NoRouteToHostException: No route to host (Host unreachable)
        at java.net.PlainSocketImpl.socketConnect(Native Method)
        at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
        at oracle.net.nt.TcpNTAdapter.connect(TcpNTAdapter.java:161)
        at oracle.net.nt.ConnOption.connect(ConnOption.java:159)
        at oracle.net.nt.ConnStrategy.execute(ConnStrategy.java:428)
        ... 36 more
Switching negate to false gave me the behavior I was looking for - thanks!
